Author Topic: Painting Alternator  (Read 3179 times)
Offline smokin-6
  • 87 T
Painting Alternator
« on: July 09 2012, 10:11:20 AM »
Has anyone painted their alternator? Mine works fine but is pretty dirty even after trying to clean it. How hard is it to split the case and is stuff going to fall out? I have dropped in the new engine and it would look nice with a clean alt.
87 T Ported stock heads, 212/212 roller, stock block, ALKY, CAS V4, 6262, 3.5 MAF & Translator, new tranny w/ 9-11
Original owner
Re: Painting Alternator
« Reply #1 on: July 09 2012, 10:17:34 AM »
I had mine powder coated.  Remember that the case is grounded to the accessory bracket and you will get a big voltage loss if you don't clean the mounting ear so it can make good contact-read the warnings here   http://www.vortexbuicks-etc.com/alternator.htm
Also a link to a page Kendall did   http://www.secondhandsix.com/misc/gntalt.htm
« Reply #2 on: July 09 2012, 10:49:40 AM »
I did the brushes in my alt & its not that bad after doing some reading on what to do. I imagine you you need to go further than I did. The steering column was much harder for me because we modified the column shift for a trans brake to not go past D if you slam it up from 1st. Still havent used it at the track, just played with it for practice so far.
Best thing is a camera to take lots of pics!!  :)
PS: Engine looks good!!  :atbeer:
« Reply #3 on: July 09 2012, 12:34:20 PM »
I painted mine - Followed Kendall's guide to disassemble and re-assemble.
Offline smokin-6
  • 87 T
« Reply #4 on: July 09 2012, 03:07:52 PM »
Those sites help with the visual, thanks
Original owner
« Reply #5 on: July 09 2012, 04:25:22 PM »
Make sure it is clocked right for re-assembly and use a paper clip to hold the brushes in the holder, the rest is fairly simple.
« Reply #6 on: July 09 2012, 05:09:18 PM »
Yep - don't make the mistake I made - when I marked the case, I marked it on the visible side - by gouging the case. Looked like crap.
