Nasty Wendy Isn't
intermittant cranking
Topic: intermittant cranking (Read 3684 times)
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
June 29 2012, 12:23:38 PM »
A friend brought me his car about 1 month ago with a no crank situation, ( lights, fuel pump, etc. came on.). I got under the car and checked to see it there was power at the solenoid at the turn of the key and I could not get a reading and after 2 or 3 tries the car all in a sudden turns over and does not act up for a month, now he is telling me the same thing is happening.
Starter does not drag, and the solenoid sounds like its ok when it was starting. has anyone had intermittant starts with a bad switch?
ULYCYC
PSI: 4
Re: intermittant cranking
June 29 2012, 12:29:20 PM »
Does it have a ign kill alarm system? That is common if it's faulty
Just a Six?
OK Now who Farted??
PSI: 2
June 29 2012, 12:41:56 PM »
Long shot but possibly the ignition switch on column has a bad connection?? Maybe when bumped (getting in or out of the car) it acts up??
TurboCajun
Keith Theriot
PSI: 1
6 Packed
June 29 2012, 12:50:33 PM »
i dont know, its an 85 but completely converted from a wrecked 86. I am going check the car tomorrow and i want to try to fix it quick because i will have to work on it in a storage center
TurboCajun
Keith Theriot
PSI: 1
6 Packed
June 29 2012, 01:26:36 PM »
I do know that he has a very very loose steering wheel, the bolts on the tilt have prob come loose
Reply #5 on:
June 29 2012, 01:44:23 PM »
the switch is down on the column and not in the hub.
http://www.vortexbuicks-etc.com/ignition_switch.htm
Check and see if the switch position needs to be adjusted a bit so that the rod that activates it to start is getting a full throw on it.
Also check for voltage on the purple wire at the solenoid, if you did not....if it has voltage, but the starter does not work, then you may have a solenoid problem. This may be what you checked? If that is what you did, then go to the switch adjustment....
and if that does not work, sounds like you need a new switch....
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #6 on:
June 29 2012, 01:55:06 PM »
thanks guys
Reply #7 on:
July 01 2012, 10:48:52 PM »
And?
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #8 on:
July 02 2012, 12:33:59 PM »
ok it did have the theft system on it, I found one relay and could not find where the light blue wire from that relay was going. so I bypassed the relay and got it working and told the owner that I would find out what causes the theft feature to activate. so my question is what causes it to cut out the gound(light blue) wire on the relay that the purple/white and purple wire are connected to?
Reply #9 on:
July 02 2012, 02:55:17 PM »
I believe the theft deterrent controller does that
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #10 on:
July 02 2012, 05:03:40 PM »
is that the other box that the light blue wire goes to. and how does it work?
Reply #11 on:
July 02 2012, 05:14:42 PM »
I don't know how it works...it is the brains of the system just like the control box you get with an aftermarket system. As far as I know, it is one of those items like a cruise control module...repla
ced, not fixed
Reply #12 on:
July 02 2012, 05:18:41 PM »
There are a number of pages in the shop manual beginning on page 133-0 of the electrical section dealing with troubleshootin
g, etc.
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #13 on:
July 03 2012, 02:05:47 PM »
well lets just consider this SOLVED because it is bypassed
Reply #14 on:
July 03 2012, 02:33:28 PM »
If all the fuses are good, then I would guess the module is the problem. Me, I am a bypasser, or I would go aftermarket
