Author Topic: preparing for paint  (Read 4235 times)
Offline shmed
preparing for paint
« on: June 26 2012, 10:02:48 PM »
ok looking at getting the t ready to paint
but dont know where to start
anyone wanna give me starting tips?
the car is brown gonna go white if that helps
Offline Scott87
  • Boost Tube
Re: preparing for paint
« Reply #1 on: June 26 2012, 10:31:51 PM »
Remove all trims, all seals... Get an idea for how many window trim clips you will need to replace..  Remove bumpers, remove grill. If a black grill you can spray it with a rattle can of satin black..
With bumpers removed assess the fillers condition..
Posted From Tapatalk
« Reply #2 on: June 27 2012, 04:56:34 PM »
start by saving alot of $$$$
Offline Scott87
  • Boost Tube
« Reply #3 on: June 27 2012, 11:39:32 PM »
If you do allot of the prepping, stripping, taping, general disassembly it should save you quite a bit labor cost for when you send it out to paint..
