Author Topic: vacuum brake conversion kit  (Read 22673 times)
Re: vacuum brake conversion kit
« Reply #30 on: July 13 2012, 10:43:47 AM »
Didn't you get a new vacuum block with an extra port for the brake booster. I get mine from Caspers if you didn't.
« Reply #31 on: July 16 2012, 04:43:24 PM »
finished!!! :rock:  Ran straight vacuum from old PCV port to booster. Ran a different line from PCV and tee'd into line going to charcol canister. Works and looks good, pedal seems maybe a little soft at first, might have to bleed them again.
Thanks for all the help!!! :atbeer:
« Reply #32 on: July 16 2012, 05:55:10 PM »
Make sure the proportioning valve is brass and not iron
« Reply #33 on: July 17 2012, 10:01:09 AM »
Didnt check that, its whatever GM put in. I'll look tonight. That link with "how to" didnt mention changing it out so I never looked at it.
Thanks
« Reply #34 on: July 17 2012, 10:34:49 AM »
Cars originally came with iron.  GM came out and advised a change to brass because the iron tended to corrode and not work properly.  I found an improvement when I changed them out.
Offline drew87gn
  • Newbie
« Reply #35 on: September 04 2012, 12:31:12 PM »
Finally found sometime this weekend to do the brake conversion. Overall the project in my opinion wasn't that bad. The brakes work but I feel that the pedal's is soft. I need to press the pedal approx. 1/2 way down before the brakes start to grab. With that said I took the car out and overall the brakes work well.......Sho uld I be concerned with a soft pedal or is this a characteristic of the conversion. I bled the brakes well, also notice that when I step on the pedal that the brake fluid bleeds back into the master cylinder. Is this OK??
Thanks
Offline gnonyx
« Reply #36 on: September 04 2012, 03:36:09 PM »
« Reply #37 on: September 04 2012, 06:27:17 PM »
I am probably long ago used to the pedal...I think it has more movement but should firm up pretty well.
Altho I normally use either a vacuum pump or the injector type bleeder depending on which I find first, I often drive the car for a few days and then do a gravity bleed by opening all four bleeders and let them drip for awhile (thru a hose to a glass or jar).  Just be sure to watch the reservoir to not let it run low during the process
« Reply #38 on: September 05 2012, 08:45:14 AM »
Sometimes air gets trapped in the front of the master cylinder sits it's tilted so much. You may have to tap it with a rubber mallet while you're bleeding it. When I did mine, it seemed the pedal was more solid with normal travel.
« Reply #39 on: September 05 2012, 09:09:26 AM »
getting the master well bled is 75% of the battle...I have pulled off the old and put the new master/booster on after a good bleeding and had good brakes even before bleeding at the wheels
« Reply #40 on: September 05 2012, 01:14:14 PM »
I agree, Steve. But the other 25% possibility of air getting into the system after a successful bench bleed is: the last line connections at the master cylinder, accidental air getting in during normal bleeding, and prior air from before the conversion (and I'm sure numerous other reasons). If any of these happen, the air could find it's way to the high spot of the master cylinder.
« Reply #41 on: September 05 2012, 01:30:23 PM »
That is the reason that the injector should work well...persona lly, I have not seen much difference...a nd, I was not disagreeing with what you said :)
« Reply #42 on: September 05 2012, 01:52:18 PM »
I wasn't figuring you were disagreeing, just adding another perspective. Not everybody has an injector. Even an injector has a difficult time getting the air trapped in an inclined master, rare as it is.
Offline I Love Factory ECMs
  • GIMP
  • PSI: -16
« Reply #43 on: September 14 2012, 06:58:04 PM »
There's aftermarket hydro boost electric motor brakes on the Web, I can't recall the place right now,but if didn't want vacume,an didn't want factoy failer again. there that last option
Enjoy!
