Author Topic: AC lines  (Read 3659 times)
AC lines
« on: June 01 2012, 08:45:50 AM »
Rock are showing 2 different AC line sets for the '98 F150.
one says -Before 4/23/98, w/o Ring Fitting At Accumulator
any easy way to tell which is which?
Re: AC lines
« Reply #1 on: June 01 2012, 08:53:52 AM »
No other differences? Can you find a build date for the truck?
Re: AC lines
« Reply #2 on: June 01 2012, 09:21:10 AM »
Look on the driver's side door-should be a tag there that will have the build date as well as other info
Re: AC lines
« Reply #3 on: June 01 2012, 09:26:01 AM »
Search here with your VIN number.  Then use the oem part number to get the right part. They may be cheaper too. http://www.fordpartsgiant.com/
Re: AC lines
« Reply #4 on: June 01 2012, 02:24:31 PM »
I had a cartful of parts saved at Rock Auto - I ended up getting the parts from Amazon, cheaper. :O
Re: AC lines
« Reply #5 on: June 02 2012, 02:31:11 PM »
Looks like its barely an '98- sept '97 build.
as others have suggested seems Ferd has almost universal replacement parts, at least the compressor and condenser appear to interchangeabl e to many vehicles.
