Author Topic: vac brakes?  (Read 2564 times)
Offline shmed
vac brakes?
« on: May 28 2012, 06:06:27 PM »
ok i have a vac brake set up on the t.
new pads rotors etc..
i went thru 1 1/2 bottles of brake fluid bleeding them
\still barely any stopping power.
engine off i can push about 3/4 of the way down after the power assist is gone
does this mean more bleding?
i start with left rear the right rear then right front an finaly left front..
an i doing this correctly?
Re: vac brakes?
« Reply #1 on: May 28 2012, 06:28:54 PM »
How are you bleeding them?  The only real success I have had is with two people, one operating the brake pedal under the instruction of the person operating the bleeder valve.
Re: vac brakes?
« Reply #2 on: May 28 2012, 06:46:57 PM »
right rear before the left rear....(passenger side before driver's side)
Re: vac brakes?
« Reply #3 on: May 28 2012, 07:58:04 PM »
New master cylinder? Did you depress the button on the proportioning valve?
Re: vac brakes?
« Reply #4 on: May 28 2012, 10:03:59 PM »
there is no need to depress the button on our generation of cars...in fact, it is already depressed and comes out when you step on the brakes...
Re: vac brakes?
« Reply #5 on: May 29 2012, 08:50:53 AM »
I found when I had an issue years back that Gravity Bleeding worked great. Also double check the adjustment on the rears & make sure the fronts are working properly with no tears in the rubber seals. My fronts were a little rough looking so I just grabbed new ones for under a $100 total. They also give back a credit for the old cores.
