Nasty Wendy Isn't
KudosVivid description. Y'all makin' me feel bad about how relatively little I'm getting done
I would have left it on the vacuum pump longer than 40 min. An opened system in humid weather sucks up alot of moisture. That may be why your only getting it down to 49 deg. With the new parts you should drop to at least 40 deg. unless your radiator is clogged and running over 220 deg. Also I like to put a few oz's of oil in the condenser after a flush is done.
Just so I don't confuse you the oil in the condenser is not extra. It is part of the total oil needed for your model car.
Aren't you using gauges?
