Author Topic: AC again??  (Read 5185 times)
AC again??
« on: May 14 2012, 10:56:34 AM »
I went out & started to try the AC to see whats up. R-12 is full & you can see that the system is trying to turn on because the fans will try to start every few seconds. Then I remembered last year at BPG the AC Cycling Switch on Accumulator needed to be unplugged & hotwired to work. When we got back i put in some R-12 & it worked fine. I changed that switch about 3-4 years ago. Just now I went to look at NOS4GN for one $21 & remembered I have a new polished Accumulator & Switch I got maybe 4-5 years ago. Totally forgot I had the switch sitting on the shelf. The problem is finding a shop to remove & save my R-12 so I can swap in the Polished parts. maybe i'll start checking around?
Anyways my question is Any ideas why the switch would go bad (if it's the issue) after only 4 years??
« Last Edit: May 14 2012, 11:00:56 AM by Just a Six? »
Re: AC again??
« Reply #1 on: May 14 2012, 11:21:15 AM »
Not sure that is the problem, but, Made Elsewhere would be my guess
Re: AC again??
« Reply #2 on: May 14 2012, 11:46:06 AM »
Are just gonna swap switches around to see if it works. I think it's on a schrader?
Re: AC again??
« Reply #3 on: May 14 2012, 11:59:10 AM »
Thats the plan later today or tomorrow. I'll keep ya posted on what happens?
Re: AC again??
« Reply #4 on: May 14 2012, 01:16:37 PM »
why swap...just jump the terminals in the connector...if the compressor runs, you know the switch is bad, or the pressure is low
Re: AC again??
« Reply #5 on: May 14 2012, 01:42:12 PM »
I'm just swapping the switch for now since freon is good & jumping the terminals makes it work fine. I'm not swapping accumulator until down the road sometime.
I just can't drive a car without AC or I'll go nuts!
Re: AC again??
« Reply #6 on: May 14 2012, 06:55:17 PM »
I understand what Steve is saying but sometimes just the goofiest stuff happens.
Re: AC again??
« Reply #7 on: May 14 2012, 08:06:15 PM »
It's what David is saying that is confusing.  If he put a jumper in it last summer, why isn't it working now?  Did he remove the jumper and leave it unworking last year?
Re: AC again??
« Reply #8 on: May 15 2012, 11:46:05 AM »
Steve maybe I misremembered??  :player:
I had a jumper in at BPG but later on at home in the fall I tried the normal hookup & the AC worked. Maybe due to cooler weather or just a fluke?
Yesterday I jumped it again & it was fine, so today I put in my shiny new Cycling Switch & it's fine. For whatever reason that switch from 3-4 years ago died on me?
It was a GM part from Glen but for $20 each no big deal.
Offline gbsean
Re: AC again??
« Reply #9 on: May 15 2012, 08:20:04 PM »
maybe if you drove it more often....these things would not happen... :D
Re: AC again??
« Reply #10 on: May 15 2012, 08:50:41 PM »
 :rofl:
Re: AC again??
« Reply #11 on: May 16 2012, 11:53:21 AM »
:rofl:
Funny Guy Eh???  :chin:
I'll drive it down the 1/4 enuf that i'll easily have 100 miles just at BPG!!  :icon_kidra:   :player:
Re: AC again??
« Reply #12 on: May 19 2012, 02:19:25 PM »
 Post your A/C and heating questions here? http://www.ihadav8.com/forum/index.php?board=12.0
AJ___
