Author Topic: No start problem found....sort-of  (Read 2098 times)
Offline grand camino
« on: May 11 2012, 07:30:11 PM »
It always starts...excep t today.  Turned key and listened for the buzz from my year old D/werks pump....nota. Fuses all ok under dash and at alt./hotwire fuse too.  Went back to tank and checked/wiggled all connections/wiring, to and from hot wire relay with the ign./key on.  Being a little pissed,i punched the gas tank and the pump started!    I cant believe there is a loose wire inside the tank as it was gone over well when the new pump went in....nor can i believe the new pump has an issue.   Guess its gotta be one or the other?  which way would you lean.  Thanks.
aka"turbocamino" 87 GN motor,trans,rear,dash. TRW+30,balanced crank and rods,max port irons+intake,cometics,212/212-500,HS1.65,6265JB,alkycontrol,stevemon.62mm T/body,JRacing 044-external,TTchips,60Lb.Motrons,RazorAlky,PTC2800L/U, NGK-PLX,GYear ssDR,3"down and out,Airbags
Re: No start problem found....sort-of
« Reply #1 on: May 11 2012, 08:04:11 PM »
I would probably lean toward the pump...but, that's just me :)
« Reply #2 on: May 11 2012, 08:07:21 PM »
As the owner of a year old DW pump I'm hoping its your wiring :) :(
