Author Topic: <SOLVED> Stuttering  (Read 25220 times)
Re: Stuttering
« Reply #15 on: May 13 2012, 11:40:12 AM »
stock reg 233
stock jectors
stock chip
I didn't want to prejudice interpretation by stating anything beforehand.
The pressure seems to follow the rules.
~close to 40 line off.
Drops with vacuum and rises smoothly with throttle. When the stutter  is happening the gauge doesn't seem to vary by more than +/- 1 LB? or less Hard to tell exactly on that small gauge.
I'd guess the problem occurs  still in the vacuum range vs boost?
It was much warmer overnight and the problem went away quickly and less pronounced so not much opportunity for capture, I was solo and didn't see the o2s.
Re: Stuttering
« Reply #16 on: May 13 2012, 12:40:36 PM »
You cannot make an interpretation without knowing the basics
stock injectors...wh o knows what might be going on after all these years with regard to gum, etc.
The SM showed it to be extremely lean yesterday...wh en in closed loop, I would expect something like a continual movement between 300 and the 700s.
Factory chip is aiming for stoch.
Okay, next time look at the blms and see what they are reporting while this is going on.
Assuming you were not under boost during the video, then the fuel pressure was probably about right.
In the mean time...try some logger shirt maintenance.  Crank it up, let it idle, and rattle each injector by holding an extension against the shoulder and tap it rapidly with a hammer...not hard enuf to break the housing of course...do each one-won't clean them, but, it might free up a sticking pintel
go to the home store, paint store, or whatever, buy a gallon of xylene and pour it in the tank with about ten gals of gas....half a tank, whatever
Re: Stuttering
« Reply #17 on: May 28 2012, 08:36:24 AM »
Well, I couldn't pronounce xylene so I swapped the injectors ( and ancilliary items).
no change. :(
Re: Stuttering
« Reply #18 on: May 28 2012, 08:52:53 AM »
so this happens in normal driving, not when in boost?
This happens in both open loop and closed loop?
Your SM showed the car to be very lean.  Once the problem goes away, do the O2s get back into a normal range?
What are your blms showing while this is going on?  What do they show when it goes away under the same driving conditions?
Offline Turbodave
Re: Stuttering
« Reply #19 on: May 28 2012, 11:40:11 AM »
H
Can you glean anything from this?
stupid cameras stupid new format stupid operators...
http://youtu.be/T_wiMWe6Ba4
How are your scanmaster IAC and TPS numbers at warm idle?
TurboDave EWCS(SW) USN (Ret.)
Sevierville, TN
Re: Stuttering
« Reply #20 on: May 28 2012, 07:13:57 PM »
BLMs seem to be 117-119 in the area of interest.
No real change cold to hot.
I want to say it still looks lean but let me confirm again, not really seeing much diff there either hot vs cold.
TPS seems to around 0.8-1.5   when it stutters.
Gotta be in vacuum still, pushing it into boost clears or masks the stutter
Now TT 5.6 installed so I'll look at open/closed loop.
hot park
TPS .38
IAC .19
Re: Stuttering
« Reply #21 on: May 28 2012, 07:21:26 PM »
so, if O2s are still lean like they were, and the blms say they are pulling fuel instead of adding it, then we seem to have a paradox, eh?
Offline gbsean
Re: Stuttering
« Reply #22 on: May 28 2012, 08:22:59 PM »
bad spot on the TPS...
Re: Stuttering
« Reply #23 on: May 29 2012, 09:46:08 AM »
will the car miss when you bring the gas up in Park?
Re: Stuttering
« Reply #24 on: May 29 2012, 09:48:09 AM »
Got anyone around that you can borrow an ecm with Powerlogger on it from?  God bless Bob Bailey and Scanmaster/Powerlogger!
Offline 1KWIKSIX
Re: Stuttering
« Reply #25 on: May 30 2012, 05:53:02 AM »
Hey Dave,
Sent you a PM on the above subject.
Dave
Re: Stuttering
« Reply #26 on: May 30 2012, 08:29:34 AM »
Yes
Re: Stuttering
« Reply #27 on: May 30 2012, 09:11:06 AM »
Just like a treasure hunt...one clue at a time
Let's see,  O2s seem low indicating it needs more fuel, blms are low indicating it is pulling fuel, fuel pressure might be okay-was hard to coordinate it with unknown driving conditions
Fueling is supposed to be easy on these cars.  ECM has a fueling curve that depends upon the maf and the O2 inputs for adjustment.  This can be messed up by unmetered air leaks between the maf and the O2 sensor.  This could be a leak between the maf and the turbo or anywhere else in the system including vacuum lines, plenum seal to intake, etc.  Also, any leaks in the exhaust before the turbo can suck air in.
At this point, we know the stutter goes away when it gets hot, but, we really don't know if the problem goes away, or simply gets covered up to some degree.
Can you tell us if this happens only in open loop operation, or does it happen in closed loop initially as well?
Also, are you running a factory original maf, a rebuilt unit, or a Translator?
What brand and how old O2 sensor?
Re: Stuttering
« Reply #28 on: May 30 2012, 11:17:10 AM »
Wonder if the egr is hanging up?  When it's stumbling at idle pull up on the diaphragm a few times and let it reseat and see if it clears up.
Re: Stuttering
« Reply #29 on: May 30 2012, 12:20:19 PM »
I appreciate the responses, bear with me as I try to give accurate answers.
New Denso O2 installed with the injectors.
Rebuilt MAF 3yrs in service, tested/bought thru turbofish.
