Author Topic: possibly found the culprit  (Read 25962 times)
Offline TURBOPOWERED68
  • David
Re: possibly found the culprit
« Reply #75 on: May 10 2012, 08:42:40 PM »
Ok, so the pins have to be  extracted with a certain tool.
I used a BIG paper clip and didn't damage any of the pins.
« Reply #76 on: May 10 2012, 09:05:23 PM »
You sound like a pro, so maybe I can send the car to you? :D
Offline gbsean
« Reply #77 on: May 10 2012, 09:20:02 PM »
http://promotorcarproducts.com/sandingpen.htm/
try this...any good body shop supply store should have them
« Reply #78 on: May 10 2012, 09:26:06 PM »
damn...that is neat!
Offline gbsean
« Reply #79 on: May 10 2012, 09:31:01 PM »
been around for years...you can trim it down with a razor blade to get into small holes...is actually made of long fiberglass strands...you can put it in a hole and twist it and it cleans the contacts...goo d for relay spades and spark plugs...
« Reply #80 on: May 10 2012, 09:39:22 PM »
I havent seen that one before gbsean
Offline gbsean
« Reply #81 on: May 10 2012, 09:43:00 PM »
If you cannot find one locally let me know and I will send you one
« Reply #82 on: May 10 2012, 10:03:05 PM »
Nice - same thing I linked to but made for a different market.
« Reply #83 on: May 11 2012, 09:00:35 AM »
Will do. Thanks.  And, i think i figured out what i'm going to do.  Think I'd rather pull each wire/pin out of the plug one by one, cut the end off, strip the wire and put new pins on each wire.  Should be cheapest route.  Keep you posted
« Reply #84 on: May 11 2012, 09:25:01 AM »
Sounds like a plan.
Many of "those" extraction tools are just a narrow strip of steel and easily fabbed.
Not seen this specific one.
Prep pen:
http://www.amazon.com/CRL-Paint-Prep-Pen/dp/B001O459NO
Can't find how fine the fiber glass strands are, ones I've used  but come in different "coarsenessess"
(granularities?)
« Reply #85 on: May 11 2012, 11:12:53 AM »
Yeah, as far as I know, I was gonna "find" a way to remove those pins.  Lol.  I suck at planning, but great at executing.  that crimper tool looks no different than some of the ones I have here at work.  I will def get that prep pen seeing that the ECM wont be replaced.  I'm going to thoroughly clean the ECM pins.  I'm so back and forth on this.  I want to just "soak" the connector in CLR because that seems the most efficient and cheapest of all possibilities. Question I have is, IDK what to expect once this job is done. Should my car "run" better, or is this just for the "comfort" of knowing that I can eliminate that as being the problem?  Thanks again for all the responses
« Reply #86 on: May 11 2012, 11:51:54 AM »
Screw it guys, think im going to spend the 60 and just splice. :013:   that's the final decision.  Let you know when it's done.
« Reply #87 on: May 11 2012, 12:03:29 PM »
and to prove thats the final decision, i just spent $69.20 for the ECM splice harness side and shipping.  When will this be over?
« Reply #88 on: May 11 2012, 02:02:33 PM »
damn, Phil! You are about as good as me at making decisions :D
« Reply #89 on: May 11 2012, 05:08:55 PM »
:rock:
