Author Topic: So much for the "low mile, no issues" transmission  (Read 19995 times)
Offline 1KWIKSIX
Re: So much for the "low mile, no issues" transmission
« Reply #30 on: March 26 2014, 06:14:56 PM »
That sounds a bit steep by me too. I agree with the advice given above.
For my money though, I'd be contacting either Lonnie Diers at Extreme Automatics or Dave Husek at Turbo Buick Performance, or Vince Janis at Janis Transmissions & shipping the tranny to them.  I'm sure that any & all of these guys can re-build your tranny for less & include some billet parts.
 :cheers:
dave
« Reply #32 on: March 27 2014, 09:04:07 AM »
Are you allowed to bring your own parts?
http://www.ebay.com/itm/2004R-STEEL-BILLET-SHAFT-FORWARD-DRUM-/171174741373?pt=Vintage_Car_Truck_Parts_Accessories&hash=item27dacf457d&vxp=mtr
Yep - I can. Thanks for the heads up, I bought it, great price - Says it's from CK, they are $400 on his site - good deal!
« Reply #33 on: March 27 2014, 06:20:44 PM »
Check it for run out once you get it, I had one my builder recommended not using.
« Reply #34 on: March 28 2014, 09:28:29 AM »
Understood.
Trans guys called tonight - 1300 for the rebuild. without the $400 drum. eek..
For a freshening I pay half that...by a 200 specialist. Chris at CK has a street/strip 200 for 1899.
 :cheers:
dave
I am going to ask him for a breakdown - He wants to do a total rebuild, I want a freshening - I think that may be the disconnect.
Will do.
« Reply #35 on: March 28 2014, 02:33:44 PM »
Mine cost me 1200 with a shift kit and billet band anchor, make sure they update the band anchor sucks when the sheer off when your chasing a harley.......
« Reply #36 on: March 29 2014, 10:37:03 AM »
http://www.transmissioncenter.net/200-4r.htm
Head over here and search page for
#22BP. 200-4R Billet Band Anchor Pin.
They also have a wide carbon band if that interests you.
Or call up David Husek at turbobuick performance. He can sell you
everything you need.
larrym who assembled yours?
Unfortunately, trans guys aren't real willing to share their secrets. They are earned, i get that. I'm glad several have answered my questions as to the "mysteries" inside the magic hydraulic box. They know they have yo by the short n curlies and apply pressure to part you with your money.
« Last Edit: March 29 2014, 10:41:28 AM by TexasT »
« Reply #37 on: March 29 2014, 12:52:20 PM »
It had a relatively new standard width Kevlar band on it. He's putting in a wider band, Alto I think. He said they should be mandatory on the 200-R4.
« Reply #38 on: March 30 2014, 02:00:36 PM »
I was lucky we have a local guru in Black Creek he puts together metric 200 3 speeds for racers. I took it to him he is a 1 man show but worth the wait IMO
Thats 1200 canadian so 1100 merican!
http://www.classracer.com/classforum/showthread.php?t=8505
« Reply #39 on: March 30 2014, 07:04:18 PM »
Here's the junk I have in my 200...and keep in mind I beat on this thing every weekend spring to fall at the track.
Art Carr hardened drum
Billet input shaft
Heat treated stator support tube
Heat treated sun gear shell
.500 tv boost valve and .296 intermediate valve
Billet anchor pin
Shift recalibration kit
10 vane pump
Biggest external transmission cooler I could find
Transmission temperature gauge...cuz heat is the number one killer
Billet servo
Extra clutches/steels
Deep pan
Offline deathraider6996
  • PSI: -1
« Reply #40 on: March 31 2014, 04:31:23 PM »
Killing me slowly lol well hopefully I won't have to worry about the tranny again for some years.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #41 on: April 13 2014, 12:10:25 PM »
http://www.turbobuickperformance.com/Standard.htm
I'd be inclined to replace the Kevlar band with a wide carbon unit. The Kevlar has been noted to overheat and warp the direct drum, or so I've read. Mr. Husek should be able to get you one.
http://www.oregonperformancetransmission.com/mm5/merchant.mvc?Store_Code=OPTI&Screen=PROD&Product_Code=ALT-43961C
or here a bit cheaper
you have to scroll down the page a bit #22x wide carbon band
