Author Topic: cam sensor ?  (Read 2672 times)
Offline shmed
cam sensor ?
« on: April 27 2012, 10:01:56 PM »
ok setting my cam sensor followed the instructions on steveds site
question my sensor only reads 6.5 v on my meter and no matter how much i turn it the voltage doesnt change
what the heck am i doing wrong:?
thanks
Re: cam sensor ?
« Reply #1 on: April 27 2012, 10:26:40 PM »
got me.  actual voltage is not important but it must drop
Re: cam sensor ?
« Reply #2 on: April 27 2012, 11:09:25 PM »
The wire in "B" does continue on to the ign module?
Re: cam sensor ?
« Reply #3 on: April 28 2012, 08:23:50 AM »
Its any help you can borrow my caspers tool?
I assume the brass wheel under the cap is tight & spinning as the motor turns over?
Re: cam sensor ?
« Reply #4 on: April 28 2012, 09:04:44 AM »
His car runs...therefo re the voltage has to be rising and falling.  B goes to a buffer amplifer in the module
Re: cam sensor ?
« Reply #5 on: April 28 2012, 09:13:59 AM »
Hall sensors can show funny if they don't have their normal load attached- why I asked.
Re: cam sensor ?
« Reply #6 on: April 28 2012, 09:29:04 AM »
Good point...
don't disconnect the cam sensor while checking voltages....se e the factory diagram at the bottom of the page  http://www.vortexbuicks-etc.com/cam_sensor.htm   The voltage is checked with the cam sensor connector plugged in
