Author Topic: translator question  (Read 5938 times)
Re: translator question
« Reply #15 on: April 27 2012, 06:47:22 PM »
when knock occurs is what is important.   But if you are happy with it, it does not matter  :)
« Reply #16 on: April 27 2012, 07:46:04 PM »
I'll try to determine when it happens, what O2's are.  Is 119 for BLM a bad thing, or is it just telling me the chip is taking out some fuel.
Not having the alarm go off all the time makes me happy :)
Thanks alot for the help!!
« Reply #17 on: April 27 2012, 10:29:20 PM »
it says there is too much fuel at that cell and the ecm is working hard to remove it
