Author Topic: type II coil please help  (Read 3490 times)
Offline Turbogn86
« on: April 23 2012, 03:39:26 PM »
Pok guys i put the type Ii coik on and cannot get the firing order it seems. Can soneone tell me why the hell its not working? Also what sensor keeps the fuel pump from comming on?
86 GN-sold
87 WE4 (Daily Driver)
Re: type II coil please help
« Reply #1 on: April 23 2012, 04:33:07 PM »
The computer tells the fuel pump to come on for about two seconds and then turn off unless the engine is started.  If it is turned off and the engine is later started, it turns back on.  As delivered from the factory, if the fuel pump relay is smoked, then cranking the engine until more than 4 psi of oil pressure is built up will activate a back up circuit thru the oil pressure trouble light sender.
Here is the circuit   http://www.vortexbuicks-etc.com/fuel_pump.htm at the bottom of the page.
I have never seen a type II system work properly under much boost, but, it should run.  The instructions are on gnttype.org.  I have not seen a conversion in years and consider them more of a problem than a fix so I am not much help.
Offline Turbogn86
« Reply #2 on: April 23 2012, 05:35:33 PM »
All i have found on gnttype.org was part numbers. I cannot locate the firing order.
86 GN-sold
« Reply #3 on: April 23 2012, 05:58:49 PM »
Offline Turbogn86
« Reply #4 on: April 23 2012, 06:28:43 PM »
All the car does is spin over amd a realy loud back fire happens
86 GN-sold
« Reply #5 on: April 23 2012, 09:22:07 PM »
I am running one on the 87. No issues - direct swap. The plug numbers are on the towers.
« Last Edit: April 23 2012, 09:46:05 PM by daveismissing »
