Author Topic: oil leak inside turbo  (Read 8388 times)
« on: April 21 2012, 12:20:29 PM »
Have a small oil leak, must be internal on the turbo, oil escapes at connection between turbo outlet and intercooler. Very small. I was going to remove intercooler and flush out with some gasoline, I'm assuming there is oil built up inside it also.
Reason for concern???
Re: oil leak inside turbo
« Reply #1 on: April 21 2012, 04:03:01 PM »
Assuming you do not have the vent line from the end of valve cover to connected to the turbo inlet, then it is a seal in the turbo leaking and it will get worse.
If you do have the line connected, remove it and put a push in KN filter into the end of the cover.  Put a rubber vacuum style cap over the turbo inlet.
Flush out the IC and go on.
« Reply #2 on: April 21 2012, 10:01:40 PM »
Vent line is not attached, its a seal :icon_confused: . Like you said, wait til the next issue comes up. Is replacing those seals a DIY job or do I need to take it somewhere. Looked in the manual you suggested getting and it seems pretty straight forward, but if I need a press or special tools I'm screwed.
« Reply #3 on: April 21 2012, 10:06:46 PM »
instructions for a rebuild are on gnttype but I think I would suggest a rebuild by someone like John Craig at Limit Engineering or a replacement
« Reply #4 on: April 22 2012, 09:27:55 AM »
When it croaks, if I'm going to have the expence I'm thinking ahead. At some point I want to add alchy. But thats it, no extreme build ups or anything. Should I get a stock rebuild or upgrade to a slighlty bigger turbo?
Thanks!!!
« Reply #5 on: April 22 2012, 09:29:19 AM »
If you want alky, then a 49 or a 44 is the perfect upgrade,
« Reply #6 on: April 22 2012, 10:24:11 AM »
You can pick up the CEA 5857...with is the equivalent of the 44 and 49 for the same price...but with all the newest turbo technology.
« Reply #7 on: April 22 2012, 11:19:50 AM »
Same place sell them? How much??
« Reply #8 on: April 22 2012, 11:27:04 AM »
$959 from Full Throttle
« Reply #9 on: April 22 2012, 11:29:18 AM »
Cottons has the 44 for $874
« Reply #10 on: April 22 2012, 12:45:50 PM »
you might look around for a mullet that thought his twelve second car will run tens if he dumps the 44 or 49 and buys a bigger turbo.....a good used 44 or 49 will do the trick as well.  check the tb.com for sale ads
« Reply #11 on: April 22 2012, 01:16:27 PM »
Steve, Full Throttle has the TE 34 57mm for $599...is that the stocker? If it is...mite be cheaper for him to buy it, than paying to have his rebuilt. He can throw alky at it later.
« Reply #12 on: April 22 2012, 08:05:17 PM »
No, that is one step up from a stocker...not a bad little turbo...I ran one many years ago....it should make high elevens on alky.  For some reason, FT is only showing me one turbo today
« Reply #13 on: April 22 2012, 08:09:08 PM »
okay, I see it...and also a 5831 billet for $649....I guess that is a billet wheel replacement for the 44?   Might be a good one as well.
« Reply #14 on: April 22 2012, 08:12:41 PM »
