Author Topic: powered sub question on porting  (Read 14063 times)
Offline TURBOPOWERED68
  • David
Re: powered sub question on porting
« Reply #15 on: April 26 2012, 08:59:54 AM »
love it  :rock:
« Reply #16 on: April 26 2012, 09:27:16 AM »
Thanks guys!
« Reply #17 on: April 27 2012, 05:02:10 PM »
Looks really good!!!!!!!!
« Reply #18 on: April 27 2012, 06:09:18 PM »
Wow!! VERY nice!
« Reply #19 on: April 27 2012, 07:47:41 PM »
Thanks guys! :atbeer:
« Reply #20 on: April 27 2012, 09:30:31 PM »
Very nice!  If it sounds half as good as it looks you are doing well!
