Author Topic: the hell is up with my 02 sensor  (Read 3689 times)
« on: April 17 2012, 01:30:20 AM »
I turned on my road yesterday and rolled the the throttle a couple times just to have the car fall on it's face.
  Then after drinking beer and watching pornography all day I remembered the couch laptop had some autosaves.
  The injectors are still squirting, the MAF is acting normal, but the O2 is dropping to nothing.
Re: the hell is up with my 02 sensor
« Reply #1 on: April 17 2012, 09:20:40 AM »
sounds like the sensor is bad, or the fuel pump is bad
I would guess the latter
« Reply #2 on: April 17 2012, 10:22:04 AM »
Expired Viagra?  :icon_eyes:
What Steve said
Offline gbsean
« Reply #3 on: April 17 2012, 08:44:52 PM »
do you have enough gas in the tank....it may sound silly...but it has happened to me....
« Reply #4 on: April 17 2012, 11:42:12 PM »
Based on the logger files, I'd say the latter too. If it was a sensor only problem it wouldn't nosedive and knock at the same time.
« Reply #5 on: April 17 2012, 11:46:56 PM »
You're probably the winner. For some reason my car runs out of gas sooner than it should since I changed to the Supra pump. I suspect the residual rust from my tank has clogged the sock and caused it to curl up some.
