Author Topic: Did I fry my ECM  (Read 9057 times)
Re: Did I fry my ECM
« Reply #15 on: April 17 2012, 02:19:07 PM »
Knowing that I would really check out all the harness wiring. Look for water damage and also around the ecm area
« Reply #16 on: April 17 2012, 05:30:45 PM »
I had the same issue lost the power wire it was a pita to get back in and solder in place so it would not pull out again chances are it is not pugging into the ECM properly. did the wire pull out of the connector or the connector out of the harness?
Offline gbsean
« Reply #17 on: April 17 2012, 08:49:39 PM »
check to make sure non of the grounds pulled out
Offline Ficco87gn
« Reply #18 on: May 07 2012, 08:11:30 PM »
After not working on my car for a few weeks due to going back to work after a 4 month layoff(Union Ironworker), I found my problem. Bad connection on the power wire. Thanks for all the good advice guys
« Reply #19 on: May 07 2012, 08:17:41 PM »
glad you found it, and glad you got back to work.  If you can find anyone to vote for that will actually encourage manufacturing in this country other than flipping burgers, vote for them/him/her
Offline gbsean
« Reply #20 on: May 07 2012, 08:22:41 PM »
funny how many times an issue is solved by checking the ECM power wire....been there done that...
« Reply #21 on: May 07 2012, 08:29:39 PM »
Now if we can teach you that it is the ecm memory wire, we will be in tall cotton!  :D
Offline Ficco87gn
« Reply #22 on: May 07 2012, 08:36:55 PM »
Glad I actually decided to go to the garage after work and try to figure it out. Now I just need to adjust my new TPS and IAC and hopefully it will fire up and break in the cam.
Steve, I hear you. As my favorite sticker on my hard hat says " Put Americans To Work Buy American
Made
« Reply #23 on: May 07 2012, 08:39:43 PM »
damn good sticker....
Offline gbsean
« Reply #24 on: May 07 2012, 09:50:56 PM »
you knew what i meant...lol
« Reply #25 on: May 07 2012, 10:04:39 PM »
yeah, but it is more fun to jab  you!
« Reply #26 on: May 07 2012, 11:24:40 PM »
Silly Brit
« Reply #27 on: May 07 2012, 11:25:45 PM »
Silly Brit
Over there, they would say Silly Twit
