Author Topic: is there a coolant drain on the 3800 series II block?  (Read 5796 times)
Offline tb3
« on: April 12 2012, 10:27:24 PM »
Im getting close to 210,000 on my 04 lesabre.  she's still running like a champ.  I had changed my antifreeze when I had to change the intake gasket , but never drained the block.  i want to do a good flush.
is there a easy to access drain on the block?
tia
Re: is there a coolant drain on the 3800 series II block?
« Reply #1 on: April 12 2012, 11:01:40 PM »
You pull the knock sensor to drain the block.  After all these years I would leave it alone.  Remove the thermostat and flush the system with the engine running and radiator plug out. Keep a garden hose in the fill. It will flush clean.
Offline tb3
« Reply #2 on: May 04 2012, 05:18:38 PM »
totally forgot about this one. lotta stuff happened in the last few weeks.
I never got any further.
another question,
I have well water, any possible long term effects with if I go pre, or post my water softener?
« Reply #3 on: May 04 2012, 05:52:10 PM »
I personally like to use demineralized or distilled water for the final fill.
