Governor spring fell off or you have a hard internal problem. Check the spring first. Easy fix.
update, didnt have the guts to tear into the tranny so took it to the shop that rebuilt it. He tells me the tranny is fine. Says the motor has a miss or fueling problem and it is causing the problem at the 1-2 shift. It does shift at WOT, it just has this weird prolonged sliding shift at about 4000 rpm's. he says the engine misses or runs out of power causing the tranny to do this weird shift. I have always felt this slight miss crusing when just a tiny bit of power is needed. Taking into a shop to put on a machine Friday morning to diagnose issue...I hope.
