Author Topic: knock on tools  (Read 12245 times)
Offline sun dog
Re: knock on tools
« Reply #15 on: January 16 2006, 09:31:37 PM »
Quote from: "Recklessrob @ Sun Jan 15, 2006 11:35 pm"
I'm not sure whether or not the car will run with the esc unplugged.
Let us know. You may set some codes doing so, but they'll clear
if you unplug the orange wire from the battery for 10 seconds or more.
Screwed around with the ESC and Knock sensor today.  I'm not familiar with the scanmaster and what info it gives you.  I use a Pro Link scan tool and get a about 30 or so parameters.
With nothing unplugged I get knock counts.  No deg retard.
With the knock sensor unplugged I get no knock signal counts. No deg retard.
With the ESC unplugged, it will start and run fine but I get instant 2 to 9 deg of retard, and knock signal counts.  I also got trouble code 43 ESC failure
With the ESC and Knock unplugged I get 2 to 9 deg retard and knock counts, even though the sensor is unplugged.  I guess the computer is making up signals?
Phil, are you getting knock counts and knock deg retard on the scanmaster reading?
The knock counter is an advancing number until it hits 255 then it resets to zero, so it will stay at the last number it was at until it advances enough to reset.  Maybe you were seeing a higher reading on the other scanner because it advanced.
As far as the integrator and block learn numbers higher than 128 are adding fuel and lower are subtracting.  It might be low fuel pressure, exhaust leaks, or injector problems.  Is the O2 moving up and down in voltage and are you getting crossovers?  Are you in closed loop?  Are you getting a coolant temp reading?  When your BL goes up is the integrator at 128?
It's always more fun to figure out someone elses car problems than your own.
 :smt071  :psix;
Nuke Gay Whales For Jesus
Offline 87natty
Re: knock on tools
« Reply #16 on: January 16 2006, 09:59:59 PM »
:prayer:  To your research!
Offline ledzeppac
knock on tools
« Reply #17 on: January 17 2006, 05:53:59 PM »
hmmmm  when the ESC is disconnected are you getting knock when in boost or just normal driving?
Offline Be4u
Re: knock on tools
« Reply #18 on: January 17 2006, 07:16:46 PM »
WATCH OUT!!!!! Phil is on to something!!!
Save the bumper fillers!
Move to Canadia!
Offline sun dog
knock on tools
« Reply #19 on: January 17 2006, 11:31:59 PM »
Quote from: "ledzeppac @ Tue Jan 17, 2006 2:53 pm"
I was in park for all of this.  I wanted to see what the computer would do with the ESC failure(unplugged).  From what I saw I was getting between 2-9 deg retard just idling and revving up.  Before I unplugged it I got no retarding, so I guess the computer bumped it up like in limp home mode to protect it self.
Is the 4.5.6.7 (deg retarding?) you were talking about only under boost, was it knocking at the same time it retarded?  Can you hear the engine knock and see knock counts go up?  You need a scanner with a flight recorder, or get someone to stare at it while you are driving and it happens.
We need a new list of what it's doing, I forgot what the original problem was now.  Did you upgrade your injectors and fuel pump when you put the bigger turbo on?
Offline Recklessrob
Re: knock on tools
« Reply #20 on: January 18 2006, 01:10:39 AM »
I'm with Natty, Nice research. :prayer:
As for knock with these cars. If its bad enough so you can hear it,
theres been some damage. The knock sensor is way more sesative.
Rob
Offline ledzeppac
knock on tools
« Reply #21 on: January 18 2006, 09:57:41 PM »
So it is even worth trying a new knock sensor and ESC module?
Offline sun dog
knock on tools
« Reply #22 on: January 19 2006, 12:10:06 AM »
Quote from: "ledzeppac @ Wed Jan 18, 2006 6:57 pm"
I would say No.  I think I would just unplug the ESC while it's idling just to rule it out, and if it makes any difference in numbers it was probably working OK.  I wouldn't recommend driving it with the module disconnected.  So the only major complaint is the knock retard under boost, Or is it affecting drivability?  How's the oil pressure? are you sure the sensor isn't picking up excessive rod bearing wear.
Offline ledzeppac
knock on tools
« Reply #23 on: January 19 2006, 04:42:00 AM »
oil pressure is great... perfect
15 or so idle and 40-50 cruise
