Welcome to IHADAV8.com!
It should work, replacing the switch with a relay driven from the window circuity.You are exposing the whole car to this higher voltage. Window Speed vs voltage would be interesting to plot.Get one of those voltage boosting supplies for fuel pumps and use it on the windows?
Measure the voltage drop across the wires, If significant put in bigger wires.Better than buggering around with the alternator voltage.Headlights brightening every time someone rolls a window....
Spray silicone on all the tracks, rubbers and felts. It works wonders and the motor won't need exotic wiring.
Toll Booth in the winter- Where else is the window speed such a problem?
Quit now, before you die.
