Neverseize the threads LIGHTLY upon install.2500 degree nickel stuff.Next time it won't take an hour like this time will.
Be very careful with never seize on electrical connections as they do cause resistance and cause the sensor readings to be off, they also can and do contaminate the O2 sensors.AJ___
Lol. So the seize that came wit it SHOULD do the job tho, right?
Permatex Copper Anti-Seize is O2 safe and has no effect on readings. Just don't glob it on. As Steve said new O2 sensors are pretreated. You only need anti-seize for re-install. Other anti-seize products like Never-seize are made for industrial use and not electrical parts or sensors.
Quote from: ULYCYC on April 09 2012, 04:17:05 PMPermatex Copper Anti-Seize is O2 safe and has no effect on readings. Just don't glob it on. As Steve said new O2 sensors are pretreated. You only need anti-seize for re-install. Other anti-seize products like Never-seize are made for industrial use and not electrical parts or sensors.Becareful with that stuff....you get it in your eyes you never-seize again
