Nasty Wendy Isn't
I suggested the Denso O2 sensor because I have heard some having problems with the recent Delcos...but, you can try one instead of the Denso brand if you want
"Denso Oxygen Sensor UniversalPart No. 234-1000 $14.39"
it seems to be more durable than the AC's. I don't use maf or O2 for fueling but I do still install one for info purposes....ne ver had one go bad yet
I just so this post for the first time Is that M5 meth.in the ALKY tank or M1 From my old motorcycle days I would say there is a hint of nitromethane and is rich.Never wire brush a plug!when you run a single cylinder two stroke you learn this real quick,no body next door to pickup the slack.My 3.8 has 5000 miles on the plugs has no seals on the EX. valve and puffs a little smoke at start up, and look way better than those.
Yeah you have to sort out that BLM issue before sorting out anything else.And Steve is right about baselining your car before trying to run it at full blast.
add a new set of plugs to the purchase...I have never had good luck getting a set of fouled plugs to run right after cleaning....
