Author Topic: Best Flat Tappet Lifter?  (Read 3591 times)
« on: March 05 2012, 06:49:24 PM »
What's your choice guys...let's hear 'em.
Re: Best Flat Tappet Lifter?
« Reply #1 on: March 05 2012, 06:55:56 PM »
One thing I took away from my choice was what Steve said about GM lifters being hardened. I have the HT969 model I think.
« Reply #2 on: March 05 2012, 07:06:51 PM »
HT969 are Sealed Power lifters.   I hear Johnson lifters is back in business and making them for everybody. But are they as good as before
« Reply #3 on: March 05 2012, 07:22:21 PM »
I think I said they had a Stellite  base...
Today, I would try the TA Performance lifters which are reputed to be hardened...may be nitrided?
« Reply #4 on: March 05 2012, 07:26:23 PM »
http://www.taperformance.com/proddetail.asp?prod=TA_V1405
would not be surprised to find they are made by Johnson as they show some Johnson lifters for the v8
« Reply #5 on: March 05 2012, 08:22:33 PM »
I ordered a TA set when they had the sale....
« Reply #6 on: March 07 2012, 01:37:46 AM »
The lifters changed but the part numbers didn't....
Johnson made the original lifters for the GN part number 959 (much like sealed powers).
the problem is that the stellite foot is no longer there, modern oil sucks, cam blanks suck, and flat tappet cams belong in a museum not an engine.
Offline tb3
« Reply #7 on: March 07 2012, 08:31:57 AM »
you still have to do some machine work to the block if you change to roller cam and lifters, correct?
« Reply #8 on: March 07 2012, 09:31:12 AM »
for some cams, maybe..others were designed for a straight install-I have not been paying attention to them lately to know which can be installed without any mods.  I think they all still have to have the spacing adjusted.
the biggest problem with roller cams is the cost.  If installing a comp flat tappet, I would pay the extra for the nitriding...an d used a hardened base lifter
