what does one quart over full do other than aerate the oil and reduce its lubricating properties? Make up for the oil you put on the floor?
Looks fine to me. Just do what you did and rotate the crank 45*-90* at a time while priming. If oil is making it out the top of the pushrods you are pretty much good to go.
If you didn`t dump a can of ZDDP in...then you just wiped the cam.
