Welcome to IHADAV8.com!
so, I am confused....yo u said it would run very badly, and more recently it would actually kill the engine. I am trying to find out if there has been any change from where it is right now, and how it has been since we started chasing the problem. At the moment, it seems close to normal as opposed to running very badly in the past.We have spent several days trying to find out why it would not run when unplugged, and tonight, it sounds like it is not really that bad. Is there a change? Further, did you drive the car? Is it still cutting out an missing when the boost starts to come up under part throttle?
Something I ran across a few times. I want you to try something. Start the car then disconnect the fuel pump. Let the car run dry and stall. Remove the schrader valve from the fuel rail. Hook up a temp hose and hold a clear bottle to catch the fuel. Hook up the fuel pump for a second and then disconnect when you get about a pint of fuel. Now look and see after the fuel settles if it's full of metal flakes and rust.Also did you buy the injectors or they came with the intake? Post the numbers that are on the injectors
