Troubleshooting a miss, etc
Pages:
2
3
4
5
11
Topic: Troubleshooting a miss, etc (Read 40791 times)
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
Re: Troubleshooting a miss, etc
Reply #30 on:
March 15 2012, 08:34:16 PM »
ok just finished changing the cam sensor cap and the ECM ( i didnt remember to check the the pinouts until i logged back on here) but the idle is worse and when i unplug the cam sensor the car shuts off
Reply #31 on:
March 15 2012, 08:48:40 PM »
lol..wrong direction of progress.
Maybe it is time to check the connector... A11 is the wire that carries the cam signal to the ecm. Make sure that pin is connected solidly to the wire and is inserting properly into the ecm
check the voltage on it as per
http://www.vortexbuicks-etc.com/ecmwiring.htm
also
Reply #32 on:
March 15 2012, 09:22:01 PM »
Also, go to the module connector and make sure all the pins are straight and inserting properly
Reply #33 on:
March 15 2012, 09:25:57 PM »
Is your module a factory unit, or one of the aftermarket replacements?
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #34 on:
March 15 2012, 09:44:48 PM »
11.26 v on A11 pin is locked in place
Reply #35 on:
March 15 2012, 09:56:53 PM »
I suspect that is a yellow wire and not black like that diagram shows, but, I am not sure...long as it is a11...
Now, if you bump the engine over, does the voltage drop low and then come back to a high voltage?
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #36 on:
March 15 2012, 10:11:43 PM »
do i check this with the ECM plugged in ,,,,,,,,,,,,,,,, module came from CASpers in 2009 when i converted from the 85 module
Reply #37 on:
March 15 2012, 10:15:49 PM »
unless failed, it should be good, then.
Yes, check with it plugged in...may be hard to see...best way would be to connect the meter and have someone watch it while you turn the crank with a socket/breaker bar...remember, depending on where the window in the sensor is, you may have to turn it over up to two times
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #38 on:
March 15 2012, 10:24:52 PM »
yes voltage drops and returns
Reply #39 on:
March 15 2012, 11:06:08 PM »
so that seems to me as if the cam sensor, the module, and the harness are working....
I have no clue why the change of ecm would make it even worse.
Is the cam sensor still clocked an 1/8" ccw from the setting position? If so, try rotating it a 1/4" in the opposite direction, CW.
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #40 on:
March 15 2012, 11:10:37 PM »
the new cap is slotted, could i turn just the cap or do I need to turn the housing
Reply #41 on:
March 15 2012, 11:19:41 PM »
it is slotted? never saw one that was slotted...that throws a variable into the equation...I guess it is slotted on both screws because you could not rotate it otherwise.
Do you still have the one I sent you?
Everything I read makes me think that the cam sensor needs to be moved a bit....but normally, you would rotate the housing.
We did check to make sure the wheel is still pinned into a fixed position so that it cannot rotate out of position, didn't we?
Reply #42 on:
March 15 2012, 11:44:36 PM »
If you have my cap, put it back on, hook up your meter, rotate the housing back clockwise a piece so you have high voltage, then rotate it back ccw until the voltage just falls..stop right there and tighten the housing clamp...in other words exactly as the book says.
If you don't, take the cap with the slots and rotate it back CW until the voltage rises, then reset CCW to exactly where the voltage falls....again, exactly as per the book
ULYCYC
PSI: 4
Reply #43 on:
March 16 2012, 07:57:41 AM »
After you get the cam sensor set by Steve's instructions and if still running bad put the old ecm back in. You need to zero in on the problem.
defective new ecm
you moved faulty wires
bent pins or not seated
chips not seated or pins bent
Also do the pinout voltage on the ecm's and ecm harness as we suggested.
Unless you have a cam that was degree in wrong Steve's cam sensor should work with out a miss even if off a few degree's.
Not sure if you checked the crank sensor. Make sure it's set correct and not rubbing (chewed up) from the balancer.
I seen head gaskets just starting push out cause the symptoms you have. Maybe a compression/ leakdown test may be in order if all above fails.
Last Edit: March 16 2012, 08:02:01 AM by ULYCYC
Scoobum
Reply #44 on:
March 16 2012, 08:20:55 AM »
Probably not related to your problem...but Dans car developed a miss last year...and it had us stumped. We swapped out the electrical stuff...and it was still there. We called in a friend that's an electrical wizard. One of the TPS wires was broken inside the insulation. Fixed the wire...good to go.
Pages:
2
3
4
5
11
