Okay...First thing I see is that the car is not making enuf vacuum for some reason. It should be reading a steady 16-17 in-hg at warm idle in gear IF the car has as stock cam. If the needle is bouncing 2-5 " hg, I would be looking for a miss, or a big vacuum leak assuming the compression is relatively similar on all cylinders.Have you warmed up the car and disconnected each injector to see if there is one cylinder, or more, that does not affect the idle speed when the injector is disconnected?Now, the car appears to be rich at idle, but, the maf is reading on the high side of the range so the ecm may be adding a bit more fuel....the cc may not be germane at idle because Eric's chip runs a form of open loop at idle for a smoother steader idle speed. I would install one of the denso O2 sensors so we know we have a good sensor. Also, we may be getting some effect from the miss....and we don't know what the fuel pressure is altho I would say it is close.Other than getting a new O2 sensor, I would leave everything else alone and try to see if you can find a miss so we don't waste time trying to tune with a miss in the car.Spray some carb cleaner around the egr, the base of the plenum, the throttle body, on hoses, etc. to see if the idle changes. Don't remember if you checked the pcv to see if it is working properly and not stuck partially open?Try Ed's suggestion to see if you get any trash out the fuel rail. Did you get the injectors new, or used?
one thing i did notice was at 35 mph in third gear the blm were @ 121-125 so it is pulling fuel
