Author Topic: Got my but kicked today  (Read 4527 times)
Offline TURBOPOWERED68
  • David
« on: February 18 2012, 09:22:27 PM »
it all started real good
Wife was busy and even offered me her "go work on the car" Blessing.
I get my stuff together and start the WB installation.
put the car on the ramps and OHHH trans fluid everywhere :013: OK worry about that later need to stay focused and finish the WB. Installed the sensor and ran the wiring backwards from the sensor to the cabin. Drilled the firewall fed the wires in, life is great so far.
i get into the car and smell a sweet smell that i have unfortunately smelled before BUT what ever i am installing the WB, Next thing you know the carpet is wet and i actually see a drip of antifreeze coming from the heater unit :013: :013:
anyway the WideBand is sortta done only need to connect it to the PowerLogger.
but now i have to replace a heater core and transmission lines  :068:
« Last Edit: February 19 2012, 09:21:49 AM by TURBOPOWERED68 »
Re: Got my but kicked today
« Reply #1 on: February 19 2012, 01:06:00 AM »
put the car on the ramps and OHHH trans fluid everywhere :013: OK worry about that later need to stay focused and finish the WD. Installed the sensor and ran the wiring backwards from the sensor to the cabin. Drilled the firewall fed the wires in, life is great so far.
Better that it happened now them when you were driving down the road. . .
AJ__
I feel for you.
  • David
« Reply #2 on: February 19 2012, 09:26:40 AM »
AJ__
I feel for you.
i did get lucky as about a week ago i took a 5.5 hour and 208 mile drive in the car :O
i bypassed the heater last night i am now going to start on the trans line. :013: Damn i wish my lift was up and running. :(
  • David
« Reply #3 on: February 20 2012, 02:09:27 AM »
before i started cutting trans lines i checked the fluid level and its still just as over filled as when i over filled it the last time. :rock:
the power steering was very low (i use trans fluid in the power steering system)
more checking to come :013:
