Author Topic: Need your help pls - what size wrench to remove brass turbo drain bushing  (Read 12352 times)
Offline 1KWIKSIX
Am going to remove my stock turbo drain line from the block tomorrow. Unfortunately , car is stored about an hour away, so I can't determine the proper sized wrenches to take.
Can anyone tell me what size wrenches I need to remove both the large brass hex bushing & the nut on the end of the turbo oil drain line?  This area is difficult to reach using an adjustable wrench as it's pretty crowded.
Thanks for your help.
dave
I had to use adjustables.. Pain in  the ass.
Offline 1KWIKSIX
yeah, guess I should'a changed it over before I put on my new TA front cover!
  :icon_eyes:   DAH.....
If anyone can tell me what size wrenches go on these two hex nuts, I'd be extrememly appreciative.
thx
dave
Mine has 1 1/4" on the block side and 1 1/16 on the flex tube
Offline 1KWIKSIX
Thanks very much!
dave
Hammer?
Offline 1KWIKSIX
turbo drain came out easily with the 1 1/16" wrench.....I used a large socket and johnson bar to remove the brass bushing...came out easy!  Much easier than using a wrench on it. I didn't have to remove the water temperature sending unit or the thermostat housing either......
