Author Topic: external transmission cooler  (Read 19783 times)
Re: external transmission cooler
« Reply #15 on: April 13 2012, 11:14:16 AM »
I will be running from the trans > radiator cooler > aftermarket Cooler > back to the trans.
« Reply #16 on: April 13 2012, 11:34:14 AM »
Wow That's an old diagram from Ken. It still works today just double clamp it.  Seems like today's offshore made hoses don't fit as tight.
« Reply #17 on: April 13 2012, 11:41:02 AM »
I will be running -6AN hoses from the trans to the cooler, I bit and paid $21.99 for the stupid expensive -6AN > 5/8ths barb fittings. :x
Offline TURBOPOWERED68
  • David
« Reply #18 on: April 13 2012, 04:47:58 PM »
i would go Feed bottom-out top TO Feed bottom - out top and then the trans.
that way it wont get air trapped in any of the coolers.
« Reply #19 on: April 13 2012, 05:52:23 PM »
I think the air would be gone about 10 seconds after the car is started.
I am thinking about putting an inline trans filter in too.
  • David
« Reply #20 on: April 13 2012, 06:05:59 PM »
if it was one tube i would agree BUT bar and plate type :hmm if you say so.
« Reply #21 on: April 13 2012, 06:15:04 PM »
given the pressure differential, I suspect any air would be pushed into the pan and dispersed into the atmosphere
  • David
« Reply #22 on: April 14 2012, 12:01:11 AM »
Not trying to challenge or be disrespectful
Assuming so, Why not hook it up the correct way anyway??
i don't get you guys?? :hmm
« Reply #23 on: April 14 2012, 01:15:39 AM »
Maybe the laws of physics are just different where you live?  :D
« Reply #24 on: April 14 2012, 09:35:39 AM »
The factory turbo buick pressure line feeds the top and out the bottom.  I think the white coats at gm know a little more then what some say on the internet. Also having the aux cooler before the internal factory one will keep from heating up your coolant in racing conditions.
« Reply #25 on: April 14 2012, 10:52:08 AM »
Normally, the external cooler is mounted such that the outlets are pointed to the side for hose routing convenience... .this should eliminate any possibility of an air pocket even tho the tranny line pressure should be sufficiently above atmospheric to force any air on thru the system and out the vent.
With regard to the factory cooler, you are pretty much stuck with factory routing unless you want to go to the trouble of changing  it around.
« Last Edit: April 14 2012, 11:02:41 AM by Steve Wood »
« Reply #26 on: April 15 2012, 01:40:31 PM »
I normally see 120-130 degrees on the trans temp gauge at cruise speeds with the big external cooler I use.
« Reply #27 on: April 16 2012, 11:22:22 AM »
so what do you see at the end of a run?
« Reply #28 on: April 21 2012, 12:03:08 AM »
160 at the end of the run. Shannonvilles return road is actually the bike track...and by the time I get back to the pits it's cooled to 150 or so. I had a link for a trans temperature chart in regards to what parts start degrading as the temp rises...but I can't find it. Dusty recommends not sitting on the footbrake/transbrake for more than 3-5 seconds...and I agree with him...as you can watch the temp rise dramatically.
« Reply #29 on: April 21 2012, 10:30:36 AM »
What does the temp peak on the brake?
