Author Topic: Bypass the safety device...  (Read 1998 times)
« on: January 31 2012, 07:19:11 PM »
Bypass the safety device, replace it with a one time fuse then bury that fuse in an inaccessible place under the door panels.Why not just replace the window motors if they are slow?
Quote
SuperSix:
Rant mode on......
Steve Wood:
cause it is hard to find a faster motor and, imo, hotwiring does not do that much...but why do some guys add jumpers instead of fixing the problem?  I always love following behind someone that likes to rig things
Pyro6:
Mcgyver'd?
At least put the fuse under the dash where you can get to it!
Re: Bypass the safety device...
« Reply #1 on: January 31 2012, 07:43:40 PM »
Mr Ohm designed a circuit breaker for that function
