Author Topic: Postons GN 107 T cam specs  (Read 9490 times)
Offline Turbodave
« on: January 28 2012, 08:58:51 AM »
Hello folks.  I recently acquired a new Postons GN 107 T cam, but without a card.  I've searched until blue in the face and have only found a couple of tid bits of contradictory information.
Anybody have an old cam card for one of these layiing around, or actually know the specs???
TIA!
TurboDave EWCS(SW) USN (Ret.)
Sevierville, TN
Re: Postons GN 107 T cam specs
« Reply #1 on: January 28 2012, 09:26:25 AM »
All I could find:
Specs from Postons Catalog
254/254..202/202(.050)...430/430..Idle to 5600rpm
and
Lobe Center 107
Advertised duration
Intake/Exhaust 254/254
Duration @ .050
Tappet Lifting
Intake/ Exhaust 202/202
Valve Lift
intkae
Intake/Exhaust 430/430
Power Range
Idle-5600
Max. RPM
6000
Seems 1BADTT on TB.com may have a print catalog - maybe he can scan for you?
Offline Turbodave
« Reply #2 on: January 28 2012, 09:54:56 AM »
Thanks a ton!  Sounds like a perfect cam to go into my numbers matching block that's getting slowly put back together.
Sevierville, TN
« Reply #3 on: January 28 2012, 10:47:13 AM »
It does sound like a great replacement cam!
