The Bastard Child Buick Board
What we used to do if we had a starter with noisy engagement was remove the solenoid and engage the drive by hand. We wanted to be able to insert an opened full size paper clip at the point where the gears mesh at their tips. GM is the only one that does this. I used to have a bunch of shims. What some people call starter alignment is more like pinion depth.
Quote from: Pyro6 on January 26 2012, 04:26:48 PMWhat we used to do if we had a starter with noisy engagement was remove the solenoid and engage the drive by hand. We wanted to be able to insert an opened full size paper clip at the point where the gears mesh at their tips. GM is the only one that does this. I used to have a bunch of shims. What some people call starter alignment is more like pinion depth. Even better than that. Most starters come with some shims, and a neat little tool. It's a 1/8" diameter steel rod about 6" long. It's proper usage is to slide it between the flexplate/flywheel teeth, and the starter gear shaft.
