Author Topic: Oil Pressure Switch/Sending Unit with only one prong?  (Read 14023 times)
Re: Oil Pressure Switch/Sending Unit with only one prong?
« Reply #30 on: February 03 2012, 08:43:34 PM »
And you really believe the response is linear?
He didn't tell us where it was off did he?
edit: I forgot the high value was defined too, so yes I defer to my elder and superior.
(zap's elder and superior? -rings a bell)
One could test at those resistance values at least.
« Last Edit: February 03 2012, 09:03:18 PM by daveismissing »
« Reply #31 on: February 04 2012, 12:17:21 AM »
depends if you believe the factory or not...aftermar ket seems to believe it is linear, but I will leave it to you to argue with them
actually, I have to look to be sure the factory one is linear...I think I plotted it out once, but, that was a long time ago.
I have never seen an electric gauge that was other than kinda close
« Last Edit: February 04 2012, 12:42:07 AM by Steve Wood »
« Reply #32 on: February 04 2012, 12:28:55 AM »
Pressure
Resistance (Nominal)
Limits
0 psi (0 Kps)240 Ohm229.0-242.5
Full Rating33.5 Ohm27.0-43.0
« Reply #33 on: February 04 2012, 12:29:50 AM »
Of course, with limits like this, how would one know if it was linear, kinda linear, sorta linear, or sometimes, maybe linear
« Reply #34 on: February 04 2012, 12:51:26 AM »
Oh yeah, just dawned on me that I was thinking of the factory temp sender which is another kettle of fish entirely so I guess I will defer to Zap to answer about the pressure gauge sender having nothing to go on but what SW publishes :icon_lol:
« Reply #35 on: February 04 2012, 09:32:11 AM »
I'm impressed,... again. :)
« Reply #36 on: February 04 2012, 09:39:04 AM »
I have a curious mind, but that was the temp sensor and it works differently from pressure
I have too many cars doing laps in my head
« Reply #37 on: February 04 2012, 09:41:44 AM »
Pressure
Limits
Looks like the mfg greatest concern is that the gauge zeros so they don't get returned as defective upon install.
A series resistor would make it read lower, shunting to make it read higher would be a pita.
« Last Edit: February 04 2012, 09:48:28 AM by daveismissing »
« Reply #38 on: February 04 2012, 10:41:31 AM »
using a mechanical gauge would be the real solution
« Reply #39 on: February 04 2012, 11:53:16 AM »
I prefer mechanical gauges for oil pressure and water temp.
