The Bastard Child Buick Board
All aftermarket only have one wire (Like my VDO) - the stock unit also functions as a switch for the fuel pump relay as well, hence the need for more wires. I would assume you have to get the same model as the one you are replacing, or a current replacement that has the same range/output. Can you see a model #/etc on the old unit? Is your builder SURE his is accurate? The gauge may be the culprit too.
all you have to do is buy the brand that matches the gauge...usuall y there is a difference between the one for a full sweep gauge and one for a 180 deg gauge...that is all you have to check
shouldn't it be the same as the one you took out?
