Author Topic: This doesn't look good  (Read 2360 times)
« on: January 16 2012, 08:53:22 PM »
I grabbed the oil cooler puck to pull the old oring out, and remove the lines, as I just ordered new cooler lines from NOS4GN.
I noticed the spring "carrier" for the relief looked bent - looks like it got tweaked/banged or something.
Sigh.. Anyone gotta spare puck?  :068:
Re: This doesn't look good
« Reply #1 on: January 16 2012, 09:33:36 PM »
I'd clean it, port it, and run it.
« Reply #2 on: January 16 2012, 10:26:48 PM »
me too
« Reply #3 on: January 16 2012, 10:45:34 PM »
Port it? I need to investigate that.
Thanks fellas
« Reply #4 on: January 17 2012, 10:41:38 PM »
