Author Topic: The All About My Monte Carlo SS Thread  (Read 53958 times)
Re: The All About My Monte Carlo SS Thread
« Reply #90 on: January 06 2013, 07:38:09 PM »
Whats the redline?
« Reply #91 on: January 06 2013, 08:53:29 PM »
Whats the redline?
It was 6500rpm when the engine was N/A... or at least that was my shift point (even when on the spray).
I hate porting stuff; so much mess.  So far I've ported two stock inlet bells, two cast iron oil drain elbows... and I still have a compressor housing to touch up. Sigh.
« Last Edit: January 07 2013, 12:02:12 PM by motorhead »
« Reply #92 on: January 07 2013, 11:46:30 AM »
So its pumping almost the stock amount of air thru the turbo, probably less with the lower boost. Sounds good to me, interested to see what Steve, Ed and Paul have to say.
« Reply #93 on: January 13 2013, 10:06:34 PM »
This is normal, right?
« Reply #94 on: January 13 2013, 10:19:09 PM »
Are you changing the body bushings?
AJ___
« Reply #95 on: January 14 2013, 07:44:27 AM »
AJ___
That's the problem... I wasn't originally planning on it.  But, I started poking around thinking about how I could stiffen up the frame to accept the added torque from the boosted engine and then out came the scraper and screw driver to clean up some scale. One thing lead to another and now I have a fair bit of body work in front of me.  This is the PS front body mount and it came out the side of the mount box. :o
« Reply #96 on: January 14 2013, 08:04:18 AM »
Interesting that one broke, when you get to the other ones that are inside the panels. :(
I have used hockey pucks in the past, cheap and solid.
AJ___
« Reply #97 on: January 14 2013, 07:18:29 PM »
The funny thing is the rubber mounts themselves are in okay shape. This is just a function of t-tops, salt and 25 years of use.  I'll build a new box and go from there.
« Reply #98 on: January 29 2013, 10:43:20 AM »
I've determined that the body is going to have to come off the frame to fix a variety of issues, including the missing bodymount(s).
Now I have to decide if I want to sink any effort into this body or this frame; buy another base-Monte that is clean, out of the States; or chop the crap out of this car and do something radical.  I am considering swapping the body onto a shortened AWD TrailBlazer SS chassis, and turboing a 5.3L.
I could recoupe a fair bit of my money by selling off the current turbo engine, built 200-4R and 8.5" to fund this... either way I am looking at a fair bit of work.
« Reply #99 on: January 29 2013, 11:10:28 AM »
What's so wrong with the current frame and body?
« Reply #100 on: January 29 2013, 01:29:45 PM »
Overall, it is looking like it is 25 years old with being exposed to humidity and salt. So to put it plainly: FUBAR... or it is going to be a long road back.
Originally I bought this car because it didn't have rotted rear frame rails, despite the doors and floors being gone.  Now the floors are going/gone again (10+ years since it was "restored") and I am not certain that I want to fix it.
« Reply #101 on: January 29 2013, 03:07:21 PM »
Ok. That makes sense.
« Reply #102 on: March 05 2013, 06:16:47 PM »
My brother and I are starting to hunt for donors... and I am thinking I am going to sell the twin turbo Gen I small block in this thing and go to to an LSX instead.
« Reply #103 on: November 21 2013, 10:10:14 AM »
I may have found a hard top donor car... should know by Sunday afternoon. More. To. Follow.
« Reply #104 on: November 24 2013, 06:20:18 PM »
We picked it up for $800; and in Buick related news it has a 3.8L.  Other than power windows this car has no options.  Hopefully we can get it home to Ottawa safely tomorrow.
