Zap *STILL* wears Depends
Check with JayC on the big board Mike. Cal would also be someone in the know. Both of them have worked on LPG systems before and they may be able to help you.
Mike, Keep up the good work, it is very impressive to say the least. I can't wait to see it actually run, I might have to make a trip Ottawa way to see it.
Apparently Kirbans thinks 120 thou is acceptable in the 4 bolt converter flangebased on the part they sent me.
By the time I was done grinding and filing I still had more than 0.002 but it sealed up OK. It was a smooth transition tho, if its straight I would think it would be ok
