Author Topic: The All About My Monte Carlo SS Thread  (Read 53932 times)
Re: The All About My Monte Carlo SS Thread
« Reply #60 on: July 23 2012, 10:09:35 AM »
plasma cutter
« Reply #61 on: July 23 2012, 12:03:04 PM »
Never had an issue with either one of ours welding just about anything Mike. Even if it's got some oil on it the welds seem to be penatrating and look pretty decent. Did have an issue with the last wire unit when the feed went wonky though. The new unit works a whole lot better but it's a 220 unit VS the old 110 unit.
« Reply #62 on: July 24 2012, 10:03:25 AM »
I was spoiled growing up when I had access to my Dad's shops and all the tools... including a really nice 220V MIG welder which I sucked at using. I was comparing my 10 year old welds to what I am doing now with this dinky hobby shop unit and really wish I had access to a better welder. I figure I'll acquire better tools over time as my skills improve.
Regardless, all of the exhaust parts are now finished. Some need to be painted in high temp paint and baked (I am going to use our BBQ... LOL), others need to be thermally wrapped as well. I'll need to build some heat shields for next to the foot wells, as this lovely old engine loves to leak a little oil and we don't want that soaking into the header wrap.
« Reply #63 on: July 24 2012, 11:34:11 AM »
Instead of the BBQ you could always build a solar oven Mike. Pretty simple to make them and they can heat up enough to cook meat safely but slowly after all. We made them in scouts as kids and it would suprise you how well they can work. :rock:
« Reply #64 on: July 24 2012, 11:46:48 AM »
He could carry his tools in a fanny pack too, but I don't think he would do that. :p
« Reply #65 on: July 24 2012, 12:52:04 PM »
I built a hobo stove a few months ago that kicked the crap out of some of my soldiers fancy jet heaters. Cost me less than $5 to make (including the fuel) and I got some Vienna sausages out of the deal.
Actually that reminds me... I have a propane space heater and an old tank (literally an old tank that they won't refill) of propane. I could just use that and keep car parts out of where my food goes.
« Reply #66 on: July 24 2012, 10:11:39 PM »
Nothing like a vacation that feels nothing like a vacation... those were my last four days "off".
Anyway it looks like everything is coming together. The exhaust fabrication is complete with everything fitted and all the welding done... coating and wrapping those parts will come later. Today I decided that I should start laying out all of the sensors, accessories, bobbles and cables... essentially everything that will be needed to make this thing run. I also pulled out the complete ECM harness, HVAC controls and some other things I have no clue what they were for - LOL. The only thing still under the hood are the headlights and horn wiring.
I have also decided that I am going to get a mini-starter to offset some of the weight I added over the nose... because this original unit is friggin' heavy. I should also add that changing the detent cable is a bitch... I switched out the carb'd one or the EFI style from a Turbo Buick as it is noticeably longer (and both cars have forward facing throttle bodies). You'll also notice that there is a cruise control unit under the hood now, I am going to have a little luxury even if I can't have AC right now.
« Last Edit: July 24 2012, 10:22:20 PM by motorhead »
« Reply #67 on: July 27 2012, 09:28:03 AM »
Just placed a call about a used 33lb aluminum propane cylinder from a forklift.
How badass would that be to see in the trunk? ;)
« Reply #68 on: July 27 2012, 09:32:50 AM »
What; now you are going camping with the car?
AJ___
« Reply #69 on: July 29 2012, 12:05:21 PM »
AJ___
Grumpy? Is that you, Dan?
Okay new question... maybe some of the farmers/engineers out there can help with this one?
I am thinking of using some SAE 100R1AT hydraulic line (3600psi WP) from a company called Pulsar (the part number is 111-03 - http://www.greenlinehose.com/_pdf/pulsar/Hose.pdf on page 6). This doesn't say if it will work with gasoline, it simply states "petroleum based" fluids (which gasoline tends to be).
If you look at the Eaton-Aeroquip catalog it doesn't indicate the application either...
http://content.yudu.com/Library/A1n54v/HoseSectionforMainEa/resources/index.htm?referrerUrl=http%3A%2F%2Fwww.thecatalogroom.com%2FEaton-Aeroquip.html - on page 30
However, if you look at this page it does state gasoline as an application (Application: Gasoline, fuel and lubricating oils, air and water.):
http://aeroquip.cc/gh663-04aeroquiphydraulichosesae100r1atgh663-4.aspx
So is this a safe, or unsafe, venture on my part?
As an aside, I don't think that running LPG through this product is going to be an issue.
« Reply #70 on: July 29 2012, 12:23:00 PM »
don't see a problem, myself
you can drop them a line and ask for insurance
« Reply #71 on: July 29 2012, 12:38:35 PM »
Same as Steve. Don't see any issues with the hose but contact them for insurance.
« Reply #72 on: July 29 2012, 01:06:13 PM »
Roger that. Thanks guys... I'll follow up in the AM.
« Reply #73 on: July 29 2012, 01:30:54 PM »
Dug the book.
AJ___
« Reply #74 on: July 29 2012, 02:44:41 PM »
Thanks, AJ. Looks like I need to read further next time... and it doesn't look like this hose is going to be LPG safe, or at least recommended per pages 351-352.
EDIT: Actually the material is safe, it is the hose the isn't being recommended due to certain hose certifications . http://www.greenlinehose.com/_pdf/hose/14.TechSpecs.pdf#search=%22propane%22 on page 171
« Last Edit: July 29 2012, 02:56:01 PM by motorhead »
