BUICKGN.COM
Author Topic: The All About My Monte Carlo SS Thread  (Read 53887 times)
« on: January 16 2012, 11:54:26 AM »
Just thought I would share some highlights/milestones in my on going TT/EFI build for my MCSS. Basically it is going to be a twin turbo 355 SBC, with a 200-4R and a set of 4.56s in the back. Full details are here: http://www.theturboforums.com/smf/the-turbo-'builds'-board/'87-monte-carlo-ss-ttefi-build/ (you may have to sign up to see the pics) because rewriting this over and over is lame.
But, if you have questions just ask. Comments will be kept to yourself... damn peanut gallery.
Re: The All About My Monte Carlo SS Thread
« Reply #1 on: January 16 2012, 12:21:35 PM »
More...
« Reply #2 on: January 17 2012, 09:41:11 AM »
So why 4.56's when the normal idea is to load turbos so they will spool easily and make some boost?
« Reply #3 on: January 17 2012, 10:55:36 AM »
I was wondering why you chose a 200R4?
« Reply #4 on: January 17 2012, 01:50:26 PM »
Gents both fair questions.
1) 4.56s because that is what is currently in the rearend and I am not funded to change them at this time. Although I want to go numerically lower. It should be noted that I am running a 28" tall tire, and considering going to a 30" tall tire in the future.
2) The 200-4R is also existing and is pretty well built. I am seriously thinking about going to a manual trans when funds allow.
Previously this engine would rev out to 6500rpm and go 110mph in the quarter NA and hit 116mph on a 100 shot of nitrous. The gears are good for about 120mph in 3rd at this same RPM +/-. It will be interesting to see what effect the turbine side of the turbos have on the powerband; I am prediciting that they will draw the RPM down some despite the Vortec heads being vastly superior to the 8445s on the Buick V6. In the future I'll be looking to larger turbos with larger exhaust housings to offset this problem.
« Reply #5 on: January 17 2012, 03:42:52 PM »
well, LC ran 4.11s in "Black" in the old days and was one of the fastest at the time with 28" tires as I recall.  Nothing ventured, nothing gained and I understand the economics.
Nice looking set up.  It's good to see someone jumping in from scratch.  It used to be the normal way before we started buying recipes.
« Reply #6 on: January 17 2012, 04:50:44 PM »
Thanks, Steve. This project has been a long time coming (6 years of planning and parts collection) and I finally worked up enough nerve to tear into a car that was running pretty well overall. Building crap with my own hands is probably the most rewarding part of the work.
« Reply #7 on: January 17 2012, 08:55:48 PM »
it always is...
« Reply #8 on: January 18 2012, 09:45:14 PM »
Got a little more work done over the last few days, specifically on the downpipe and some minor system adjustments. There were definitely some things to take into consideration when putting the downpipe together, not just the physical bits that get in the way or the distance around those things that are heat sensitive (fluids, rubber/plastics and electronics); but also the functionality of the piece and surrounding components. Things like accessing the power steering cap or being able to install the front header bolt which also holds the brace to the turbine inlet flange. In the end it worked out if not for looking a little askew. Overall the clearances are good.
 Onto the passenger side...
 Oh and I started dinking around with the air filter placement/routing.
« Reply #9 on: January 18 2012, 09:46:44 PM »
One more...
« Reply #10 on: January 18 2012, 11:10:20 PM »
good thread.
Offline TURBOPOWERED68
  • David
« Reply #11 on: January 19 2012, 08:22:44 AM »
is this an old school SBC?
« Reply #12 on: January 19 2012, 09:43:33 AM »
It is. Based on a Gen I (Mexican cast and built) 4-bolt main Goodwrench crate SBC with Vortec heads (semi Gen II).
« Reply #13 on: January 19 2012, 10:45:04 AM »
The more askew a turbo car looks, the more impressive it becomes to onlookers!  Weld it up well and take your time grinding the welds smooth and it will draw plenty of oohs and ahs....
« Reply #14 on: January 19 2012, 12:14:30 PM »
Are those nylocks on the exhaust input flange bolts? Won't those melt?
