Thanks Mark and Dave
2
Topic: Thanks Mark and Dave (Read 6202 times)
Pyro6
PSI: 2
January 11 2012, 05:56:16 PM »
I got a call at the shop Monday from a new customer. Just out of the Air Force, just bought an 87 GN. He was hunting for someone to work on the car and he wanted a GN guy, Dave and Mark sent him my way. He came in to talk about what had happened within an hour of the initial call. On the way home from the car dealer, the radiator blew and until he got a place to pull over, it started missing like a bitch. He towed it home, put a rad, water pump, NGK plugs, and a coil pack. Still missed. He took compression test, 5 & 6 dead. Joined up with a bunch of the websites and got my name from one of them, thanks to Mark and Dave. I figured I would post if anybody was interested how it's going.
Unfortunetly, he bought the car "as is". He towed it in, we started on it Tues. I first double checked compression w/the same result as him. Pulled the valve covers, first noticing dislodged exhaust pushrods 5/6, pulled em and they were bent. Looked closer and saw the valve springs were still compressed too. Pulled the heads, took em to the machine shop Wed. AM first thing. My machine shop tech, (Chad) and I looked them over and decided when the rad went, it got hot enough for the valves to stick and the rest is history. As always, money is an issue, and he hasn't even driven the thing yet. We're gonna do our best for him to get it driveable in the long term for a base to work from. Than, any mods, he can do from there. It's a nice, repainted, reupholstered, nice DD. Chad will redo both heads, expecting minimum all new exhaust guides plus the normal stuff. I'm replacing the 2 lifters and pushrods of the affected cyls. I was concerned when taking it apart of the coolant laying in the OEM air filter housing. I flushed the IC as a precaution. Also, the valves did hit the pistons. It nicked em and I seriously considered pulling the block. They weren't deep gouges but did have enough to give a small amount slag that would stick up. I studied it for the longest time. Given the finances of the situation, I decided to bring each piston up, carefully Dreml the slag and ponder again. One of those decisions you hate to make, but I think it will be fine. He isn't planning on racing it so we're gonna move on.
Pyro6
PSI: 2
Re: Thanks Mark and Dave
January 11 2012, 06:14:30 PM »
Took some pictures on disassembly
January 12 2012, 12:28:42 AM »
I think smoothing out the dents so there are no sharp edges to get hot will do it okay. I have seen it before.
Tough luck, but, I am glad he found you.
Pyro6
PSI: 2
January 12 2012, 08:23:43 AM »
Thanks, Steve. Hopefully we can get him back on the road soon. I suspect the heads won't be done until Tuesday. Until than, clean and prep.
daveismissing
January 12 2012, 08:31:50 AM »
Did the rad let go because it got pressurized? Head gasket?
Pyro6
PSI: 2
Reply #5 on:
January 12 2012, 09:09:29 AM »
Head gaskets were ok. I didn't see the rad.
SuperSix
Administrator
PSI: 234
Reply #6 on:
January 12 2012, 10:34:39 AM »
Good to know - thanks for the repair notes.
I'm a relative newb, but I never heard of a head getting so hot that the valves stuck. WOW.
And thank Dave - I only made a smart ass comment.
Reply #7 on:
January 12 2012, 11:05:41 AM »
It usually happens when they are a really hot. Probably not as much oil at the rear to carry away the heat so they galled. Guy musta really cooked it.
Check his oil pressure when you get it back together, Gary. Makes sure it responds to the throttle as it should just in case he has a problem there. Tired pump or worn front cam bearing can wreak havoc at the rear of the engine.
Pyro6
PSI: 2
Reply #8 on:
January 12 2012, 02:12:22 PM »
Mark, smart ass comments are expected
. Steve, the extent of overheating is yet to be seen. The car shows 53k. I was looking for overheat damage on disassemble but didn't see anything. Will put op gauge on, thanks.
Last Edit: January 12 2012, 02:16:28 PM by Pyro6
Pyro6
PSI: 2
Reply #9 on:
January 26 2012, 05:51:26 PM »
Finishing up on the 87. Was held up a week from a supplier that let my order get put aside and forgotten. I won't mention any names but his initials are Jason
No biggy, the customer was o.k. Today was an assembly day, should be running tomorrow.
SuperSix
Administrator
PSI: 234
Reply #10 on:
January 26 2012, 06:15:28 PM »
Sweet. I was wondering about the progress.
Pyro6
PSI: 2
Reply #11 on:
February 01 2012, 08:23:54 AM »
Customer was happy to pick his car up Monday night. I had a huge list of things that still need done, like a Scanmaster for instance. Just got an e-mail from him: the alternator went out on the way home, he made it o.k. though. He said he got all kinds of questions at the gas station. Sounds like he's enjoying the car already.
Reply #12 on:
February 01 2012, 09:49:00 AM »
tell him to buy an alternator for:
1996-94 Buick Roadmaster 5.7L, 1996-93
Cadillac Fleetwood Brougham (RWD) 5.7L,
1996-93 Chevrolet Caprice 4.3L& 5.7L,
1996-95 Chevrolet Impala 5.7L,
1995-92 Chevrolet Lumina APV Van 3.8L,
1995-92 Oldsmobile Silhouette 3.8L, and the 1995-92 Pontiac Trans Sport 3.8L
This alternator was also installed on police cars, and fleet vehicles such as taxis where normal operation may include lots of non-moving use with heavy radio traffic.
It is listed as a Lester no. 8112 which may be helpful at wrecking yards, or such places.
This is the standard Impala alternator which is rated at 140 amps. Has about 30 amps more at idle than ours and is the revised GM CS144 that is more rugged than ours
Plugs right in
Last Edit: February 01 2012, 09:57:34 AM by SuperSix
Reply #13 on:
February 01 2012, 09:52:49 AM »
where the heck are these formatting codes coming from?
SuperSix
Administrator
PSI: 234
Reply #14 on:
February 01 2012, 09:56:20 AM »
Looks like you copied and pasted into the reply with the WYSIWYG editor active.
I will clean it up
2
