Author Topic: Turbo question  (Read 4922 times)
Turbo question
« on: December 27 2011, 07:03:16 PM »
Is there a turbo that uses the stock IC turbo housings but has a 60-1 compressor wheel in it? What's the name if it if there is, Thanks.:)
Re: Turbo question
« Reply #1 on: December 28 2011, 01:28:52 AM »
YOu check the old turbo wheel list on gnttype?
Re: Turbo question
« Reply #2 on: December 28 2011, 11:41:49 AM »
I know what thread Charlie's been reading....
Re: Turbo question
« Reply #3 on: December 28 2011, 01:32:34 PM »
It really doesn't give that good a discription of which compressor and which turbine Steve, that's why I was asking.
I just trying to figure put what to cal this thing Dave. It really is a hybred type after all but it's not easy to figure out what it should be called for marketing and identification purposes.:)
Re: Turbo question
« Reply #4 on: December 28 2011, 11:02:39 PM »
Re: Turbo question
« Reply #5 on: December 28 2011, 11:15:26 PM »
I spent a lot of time looking at the chart Steve and it's te or ta but the confusion is between which 60 or 61 series it is. I was hoping to get an answer on which turbine is used so I might be able to call it a DT 60-? for the turbine but I still haven't heard from the turbo guy as to which turbine it'll end up with.:(
Re: Turbo question
« Reply #6 on: December 29 2011, 02:50:21 PM »
Well the turbo guy got back to me today and gave me the info I was trying to figure out. The equalivilent IC turbo is a TA-62 uses 60-1 compressor wheel, P trim turbine wheel, stock 86/7 housings. Looks like a huge advance for the C/T cars now.:)
Re: Turbo question
« Reply #7 on: February 20 2012, 02:53:58 PM »
Re: Turbo question
« Reply #8 on: February 20 2012, 03:49:03 PM »
GN/Ttype didn't list the compressor or turbine on most of those Chris. Thanks for the input though. :cool;
Re: Turbo question
« Reply #9 on: February 20 2012, 06:51:29 PM »
Are you looking for a turbo not on that list?
Re: Turbo question
« Reply #10 on: February 20 2012, 07:40:07 PM »
It's a hybred turbo Chris. I was trying to get an idea of how well it will work on the draw through system so I needed a better idea of what a rough equalivilent would be. The current design is a very old Cheeta (sp) stage II which doubles the original flow of the stock one. With this new 60-1 compressor and P trim turbine it will flow three times the original. :rock:
Re: Turbo question
« Reply #11 on: February 20 2012, 07:49:21 PM »
Gotcha.
