How fast do you want to realistically go?
great info,thanks. Can fully ported stock irons reach the same flow #s that champ.ported irons do? As far as losing some low end power...i felt that with the faster billet wheel spool up i've seen and the added torque from e85 as well as alittle more stall, things would work well together.
What intercooler are you using?
Quote from: Pyro6 on December 22 2011, 05:56:21 PMWhat intercooler are you using? Its a front mount...probab ly not alot better than a stocker...mayb e a little wider though. Interesting question....wh y?
remember you should raise the compression ration about one point when using aluminum heads to regain the thermal efficiency lost with aluminum headsPersonally, I prefer the iron heads unless one is running in the low tens.
