Author Topic: TA timing cover on sale 'till 16'th  (Read 18584 times)
« on: December 13 2011, 01:58:46 PM »
see front page , call for discount
http://taperformance.com/
Offline tb3
Re: TA timing cover on sale 'till 16'th
« Reply #1 on: December 13 2011, 11:13:14 PM »
I wonder where highway stars gets theirs?
are they nos?
http://www.nos4gn.com/servlet/the-586/25522648-engine-timing-chain/Detail
« Reply #2 on: December 13 2011, 11:20:21 PM »
It's almost like TA knew I was going to make a run of timing covers.....
Offline turbo nasty
  • Newbie
« Reply #3 on: December 14 2011, 03:43:50 PM »
The TA piece is the one to get since their final machining is done by them to much tighter tolerances.
 I recentlyand setup a Brand new GM cover from Nos 4 GM.....and brand new out of the box the pump cavity was outside the spec.
87 GN New Zimmerman Powerplant in the works!!!GT3255E, Alky, ESP FMIC, GEN2 w/LS1, Ext G, HR Bar, UMI, Bertram/White/EA Stg2 Trans, yadda yadda
Offline turbo nasty
  • Newbie
« Reply #4 on: December 14 2011, 03:45:06 PM »
Forgot to mention the cover you can get from Auto Zone I think its Dorman the oil pump drive shaft wouldnt go through the hole...Fail
Larrym What did you buy???
« Reply #5 on: December 14 2011, 09:46:06 PM »
So tell us Larry, local crap, TA or Orig GM??
Offline 1KWIKSIX
« Reply #6 on: December 14 2011, 09:56:18 PM »
Looks like Santa arrived early:
Ordered mine yesterday..... but went for the TA1530A, it's only a couple of bucks more and has got the front seal retention screws to prevent front seal blow out.    :023:
Since the front cover will be off....also ordered their steel billet timing chain set with stock style chain & tensioner.
While I'm in there and have it all apart, would be a good time to  put on the new AC Delco Water Pump I've had sitting on the shelf.
New Valve Springs and should be good to go in the spring!   :icon_keel:
« Reply #7 on: December 15 2011, 01:05:54 AM »
I haven't bought any yet....... Richie had an old one I just finished pulling it apart but I think it is too worn gear pocket is galled up and the shaft bore has some play. Christmas and 4 kids has me maxed out on the credit card LOL so it might have to wait till the new year. I will go with the TA hope I can catch the sale price would really like the fully assembled peice.
Offline tb3
« Reply #8 on: December 15 2011, 04:23:55 AM »
I've heard of fitment issues with the parts stores covers also.
as far as the ta covers, the (possible) advanatages I can think of off the top my head would be:
the front mounted seal
fits 14 or 20 bolt pan/blocks
has the longer oil pump gear cavity.
friend of mine local bought one for his 9 sec car and no issues, but did have alot of casting flash to clean up.   I just did alot of casting clean-up for another buddy of mine recently, but his engine isn't done yet.
earl brown,  I'm in no hurry, but I'd like to buy one of your covers if you do another run of them
« Reply #9 on: December 15 2011, 09:38:34 AM »
Earl Brown's all the way...nothing to clean up after-hand massaged for ultimate flow, no need for hv pump gears that ultimately wear out the front cam bearing....mor e flow without resorting to more strain.
Offline tb3
« Reply #10 on: December 15 2011, 11:28:10 AM »
What about the guys with the really fast builds for mostly the drag strip that have the bigger cams and such?
would the hi volume gears benefit them?
« Reply #11 on: December 15 2011, 01:49:06 PM »
.....but went for the TA1530A, it's only a couple of bucks more and has got the front seal retention screws to prevent front seal blow out.    :023:
Well, $50 difference this week...
« Reply #12 on: December 15 2011, 02:02:11 PM »
You only need a high volume pump if your system will not maintain sufficient oil pressure for your needs.  If the oil pressure is there, then the volume is enough.
There might be an engine built so loosely, that the pump's output cannot maintain the desired pressure.  That would be an engine destined to be rebuilt frequently like an all out, very high rpm race engine.... probably built by an old timer that used to build chebbies?
« Reply #13 on: December 15 2011, 08:09:00 PM »
I have done 5 used GM covers (I have a NOS to do this winter) & they are all 25 hot idle with 10-40 & hit 50+ with any RPM using Earl's tricks. Thanks Earl!!!
The used covers cost me under $100 each shipped & even with some specs slightly out (end play) I still haven't had any issues nor have the 2 guys that have used them. The one thing they all needed was the pump cover machined flat because for some reason they were all High in the middle where the gears wear? At first look you would think they would be low in that area but all were high????
Offline tb3
« Reply #14 on: December 16 2011, 02:21:35 AM »
now I know, thanks steve!   :icon_super:
