Okay, maf should have read 4-6 so a higher reading than that makes the the computer think the car is too lean and it adds fuel...that is why you are seeing 150 on the blms....
The best route is to install a Translator on the car...or you can try to buy a rebuilt maf and see if it works properly...tha t is hit or miss. If you go that route, be sure it is built just like the original. same shape inside and the connector in the same place...don't take one that is necked down inside, or otherwise different. If it does not read 4-6 at idle, take it back. If it does, go wide open throttle and see what it reads. At 15 psi of boost or so, it should read at least 240-245
