Author Topic: FP gauge  (Read 56592 times)
Re: FP gauge
« Reply #15 on: December 13 2011, 10:03:32 AM »
I have been scouring ebay etc  for a while looking for affordable quality transducers.
Lots of mis-labeled stuff etc.
Accurate industrial units with chemical resistance tend to be in the $150-500 range.
Accuracy doesn't seem to be a prerequisite in the automotive arena.
This surprises you?
AJ___
Re: FP gauge
« Reply #16 on: December 13 2011, 01:59:09 PM »
The one I posted is now $130 so you just saved $20 and did not have to scour anything-I believe Motormouth Mike told me about it so it is Canadian approved as well.  Such a deal
Re: FP gauge
« Reply #17 on: December 13 2011, 02:01:09 PM »
Re: FP gauge
« Reply #18 on: December 13 2011, 04:17:07 PM »
vay!
Re: FP gauge
« Reply #20 on: December 21 2011, 02:45:51 PM »
Do you absolutely have to have it visible? You could always mount it in a cup outside the windshield. Then you could use a mechanical gauge.
I would need it to be visible because I need to see if the FP is rising with boost.  Thanks for all of the replies
Re: FP gauge
« Reply #21 on: December 21 2011, 02:49:41 PM »
A few of the locals have these, tuck them under if not tuning
http://www.metcomotorsports.com/proddetail.asp?prod=MFP0003
This seems like it'd be a good route to go, but what would support it if its above the hood?
Re: FP gauge
« Reply #22 on: December 21 2011, 04:29:31 PM »
I use on of these and tape it to the wind shield test the pressure then take it off good for checking my other vehicles too.
http://www.jegs.com/i/Sunpro/885/CP7838/10002/-1?parentProductI d=1662067
Re: FP gauge
« Reply #23 on: December 21 2011, 05:43:18 PM »
It probably wouldn't be too hard to fabricate a temp mount for that as well
Re: FP gauge
« Reply #24 on: December 21 2011, 06:01:11 PM »
A reason the guys like the metco - it is a std braided line with another layer over it. Leakage very unlikely.
Re: FP gauge
« Reply #25 on: December 22 2011, 05:01:17 PM »
Thanks for all the replies.  I always figured FP was something that needed to be monitored at all times, oppose to just tuning.  But it makes sense, this is the route that i will most likely go.  Thanks again
Offline gbsean
Re: FP gauge
« Reply #26 on: December 22 2011, 08:27:57 PM »
stay away from the Autometer...ha d nothing but problems with those...use the motor sports innovations one...here is a thread from a board that used to be good http://www.turbobuicks.com/forums/buick-v6-turbo-tech/86928-pl-fuel-transducer-issue.html
Re: FP gauge
« Reply #27 on: December 27 2011, 09:52:20 AM »
So, my cousin Charles came over on the weekend, and happened to have a fuel pressure gauge. We plugged it up, and with line on, the FP read out at 60. Line off it was at like 50 or so. The car is pretty much stock outside of an exhaust and air intake. It's pretty sad that my mechanic didnt ever check the FP when the car was there. Oh well. So of course the car was running rich and could possibly explain the sluggishness of how it was running. We adjusted FP and the car seems to run a lot better.  Still have a LOT of tuning to do though, but this is a start.
Re: FP gauge
« Reply #28 on: December 27 2011, 09:59:21 AM »
Whooooooooooo!!!
Damn good Christmas present. ;)
Re: FP gauge
« Reply #29 on: December 27 2011, 11:14:16 AM »
Whooooooooooo!!!
Exactly what i said.  Lol.
