Author Topic: Google Search  (Read 7251 times)
Google Search
« on: November 21 2011, 07:02:10 PM »
I've notice this have been getting worse-
Google had depreciated the "+" character when searching.
Put your search terms in separate quotes seems to be the way:
"antenna" "removal"
http://www.google.com/support/forum/p/Web%20Search/thread?tid=151ef6cf0a761b74&hl=en
Re: Google Search
« Reply #1 on: October 09 2012, 09:45:02 AM »
"antenna" "removal"
The boolean search is pretty much useless on goodle and the bubble search getting worse for most people.
I have been using duckduckgo.com for some time you can use boolean with it and it works quite well. It also has bang which with the ! you can search a specific site for what you define.
eg:  http://duckduckgo.com/?q=Steve+Wood+!turbobuicks
Takes a bit to get used to the layout as it is pretty basic. You can customize it to your liking a little.
Best part is no info storing or tracking or refeerers etc. A few times I have seen a couple refers may have been when they where changing or working on the server but that has not happen in some time.
No page number either just keep scrolling and the search will continue and display.
Also if you are using Firefox; Ghostery works well.
There are a few other add-ons that you can use too.
If someone knows of a better current engine please post it up.
AJ___
Re: Google Search
« Reply #2 on: October 09 2012, 10:02:40 AM »
probably worth looking at, only tried it a few times:
http://qrobe.it/
Re: Google Search
« Reply #3 on: October 09 2012, 10:22:37 AM »
http://qrobe.it/
Redirects galore on that.
Here is just one.
grobe.it a redirect from 57285.bestfast get.com to ck.ads.affinit y.com, which is part of Affinity.
AJ___
Re: Google Search
« Reply #4 on: April 25 2013, 09:27:05 AM »
Re: Google Search
« Reply #5 on: April 25 2013, 10:09:55 AM »
I can still get around on google fairly accurately..
now ebay on the other hand.....   whey in the hell did they get rid of the * wildcard?  they have basically ruined their searching. Between that and not being able to search just the tittles it's agonizing looking for something odd and specific
